Jia,
This diagram: https://dl.dropbox.com/u/15562376/bin.jpg is wrong.
You should look at klems_int.cal to determine what the patch numbers are.
My bad.
Andy
On Sat, Oct 20, 2012 at 5:11 AM, Jia Hu <[email protected]> wrote:
Hi all:
I have a question about the bin number.
To calculate view matrix: (south-facing window)
$ rtcontrib < test.pts -f klems_int.cal -bn Nkbins -b kbinS -bn Nkbins -m
window_mat -I+ -ab 3 -ad 2000 -lw 1e-4 interior.oct > south.vmxkbinS uses the (0, 1, 0) as normal (pointing to inside room).
For a ray direction (-1, -1, 0), using klems_int.cal to calculate the bin
number, the bin number is about #57 (I did it manually).Klems_int.cal (download Klems_init.cal<https://dl.dropbox.com/u/15562376/klems_int.cal>\)
seems use "z" hemisphere (see this figure:
https://dl.dropbox.com/u/15562376/coordinate.jpg\). From the figure, we
can see "z" hemisphere points to the room (that is, the hemisphere is
located in the room) "zr" (z reverse) hemisphere is towards outside (the
hemisphere is outside the room).The possible inconsistency is:
(1) Klems_int.cal uses "z" hemisphere to calculate the bin number, for
example, for ray direction (-1, -1, 0), the bin number is #57 for "z"
hemisphere coordinate. (see this figure:
https://dl.dropbox.com/u/15562376/bin.jpg\)(2) The "Transmission Back" data in the BSDF .XML is used in the three
phase DC method (see Greg's explanation<http://permalink.gmane.org/gmane.comp.graphics.radiance.general/2729>\),
and thus the calculation is based on "zr" (z reverse) hemisphere , for ray
direction (-1, -1, 0), the bin number is about #69 according to the "z
reverse" hemisphere coordinate (see this figure:
https://dl.dropbox.com/u/15562376/bin.jpg\).So my questions are:
(a) Given the ray direction, which hemisphere ( "z" or "zr" ) does
"Klems_init.cal" use?(b) whether the bin numbers (for the same ray direction) between
"Klems_int.cal" and BSDF .xml are inconsistent or not?(c) if they are using different bin numbers, how to handle ViewMatrix *
BSDF in the calculation?Thank you in advance,
Jia
