I am playing with a very simple room that has a light pipe in it.
I've created a global and a caustic photon map. When running them
through pmapdump, all caustic photons have a zero radius. I am
attempting to fix this with the -r option, but it gets ignored. Is
this expected?
The man page states that
"In cases where the distribution is substantially nonuniform (e.g.
highly localised caustics) the radius can be manually corrected with
this option."
Does pmapdump know whether it is dealing with a 'substantially
nonuniform distribution', and ignore -r if it is not?
Thank you
Axel
Hi Axel,
Actually, the -r option is just a scaling factor, so scaling zero doesn't change anything. The basic radius is derived from the cube root of the photon cloud's bounding box volume divided by the number of dumped spheres. In this case it would a imply a zero volume. What's the pmap's bbox reported by getinfo?
--Roland
this expected?
this option."
Hi Roland,
$ getinfo tmp/lp3_g10000-c100000.cpm
tmp/lp3_g10000-c100000.cpm:
#?RADIANCE
mkpmap -n 32 -apg tmp/lp3_g10000-c100000.gpm 10000 -apc
tmp/lp3_g10000-c100000.cpm 100000 -apo dome_mat octrees/lightpipe3.oct
NumPhotons = 106896
AvgFlux = [1.71e-05, 1.71e-05, 1.71e-05]
Bbox = [14.751, 26.064, 2.950] [15.249, 26.563, 2.950]
CoG = [15.000, 26.313, 2.950]
MaxDist^2 = 0.029
FORMAT=Radiance_Caustic_kdT_Photon_Map
VERSION=3.0k
this expected?
this option."
Hi Axel,
by getinfo?
--Roland
Hi Axel,
thanks for the info, and for pointing this out; the photons are coplanar, so an area metric should actually apply.
I'll update pmapdump.c accordingly in the coming days. Will drop you a line so you can try it out.
--Roland
On Tue, 05 Dec 2017 18:20:48 +0100, Axel Jacobs <[email protected]> wrote:
Hi Roland,
#?RADIANCE
NumPhotons = 106896
Thank you, Roland,
my scene is a simple light pipe with a planar diffusor at the end. I managed to change the zero radii to something non-zero and visualise the photon map. As you say--all red (caustic) spheres are on the diffusor.
Thank you for fixing this.
Cheers
Axel
On 06/12/17 18:19, Roland Schregle wrote:
On Tue, 05 Dec 2017 18:20:48 +0100, Axel Jacobs <[email protected]> > wrote:
Hi Roland,
#?RADIANCE
NumPhotons = 106896
Hi Axel,
--Roland
Hi Axel,
thanks for bringing this to my attention, and nice workaround too. Pmapdump was originally (and still is pretty much so) a bodge for visually debugging mkmap's output when weirdness happens. But I'm glad it comes in handy to others too, and as such I'll make it a bit more robust. Hope to check in the update by the weekend.
--Roland
On Wed, 06 Dec 2017 20:25:32 +0100, Axel Jacobs <[email protected]> wrote:
Thank you, Roland,
Dr-Ing. Roland Schregle
Gemeindehausplatz 6
CH-6048 Horw
Hi Axel,
No prob. I just updated pmapdump.c in the CVS. Try that with your original (coplanar) caustic pmap.
The automatic sphere radius is a pretty rudimentary guess and often needs some manual tweaking. Usually it's too small, but on the upside that reduces sphere overlap, which would otherwise slow oconv down. Pmapdump is still pretty rough around the edges, even after over a decade... ;^)
Best regards,
--Roland
Thank you, Roland,
