Photosphere (or equivalent) in Linux or Windows?
Dear Radiance community,
There was a great effort a couple of years ago to create a cross-platform version of Photosphere by Greg and Helena Eydelberg. Is this version perhaps stable enough for distribution?
Otherwise, what would you use as an alternative if not Photosphere? Has anyone used successfully any other workaround (e.g. an OS X virtual box)?
Thanks for any ideas!
Kynthia Chamilothori
I also developed a window based software a few years ago to work with HDR images. You can download it from this link: http://aftabsoft.net/AftabAlpha/Software/Aftab_Setup.exeThey are some tutorials for it here http://aftabsoft.net/aftab-alpha.html
Regards,Majid
On Thursday, June 2, 2016 7:09 PM, Nathaniel Jones <[email protected]> wrote:
He Germán,
I recall having the same problem when I installed hdrscope on Windows 7. As I recall, I had set a system-wide RAYPATH, but it turned out that the installer only checks the user environment variables. Adding Radiance to the user PATH and RAYPATH, then running the installer, and then removing the user PATH and RAYPATH seemed to work.
Nathaniel
On Thu, Jun 2, 2016 at 12:58 PM, Germán Molina Larrain <[email protected]> wrote:
Thanks, Mehlika.
I downloaded it from http://courses.washington.edu/hdrscope/download.html and installed the NREL Binaries for Windows (they are working), but the setup still tells me that I need to install Radiance.
Is that a known problem? when I put "echo %RAYPATH%" in the command line, it returns the correct path.
Germán
2016-06-02 13:39 GMT-03:00 Mehlika Inanici <[email protected]>:
Hi German,
hdrscope works in Windows 10. That is what I am using. You need a valid Radaince installation and path and raypath set to Radiance/bin and Radiance/lib.
Mehlika
On Wed, 1 Jun 2016, Germán Molina Larrain wrote:
Have you heard about HDR Scope??? I saw a demonstration given by Mehlika Inanici once... it was REALLY COOL. For Windows only, though.
Anyone knows wheather it has been updated to work in Windows 10?
2016-05-31 9:45 GMT-03:00 Chamilothori Kynthia <[email protected]>:
  Thanks for your answer\! Great to hear that the Windows port is stable and working\!
  I completely understand the difficulty of continuing the porting work \- thanks for all the work you have already put into this\. I think that for what I want to do
  hdrgen and pcomb will do fine for now\.
  Kynthia
  Message: 3
  Date: Mon, 30 May 2016 08:40:58 \-0700
  To: Radiance general discussion &lt;radiance\-general@radiance\-online\.org&gt;
  Subject: Re: \[Radiance\-general\] \[HDRI\] Photosphere \(or equivalent\) in
          Linux   or Windows?
  Message\-ID: &lt;519C9544\-A8CF\-430D\-8857\-27537814B93B@lmi\.net&gt;
  Content\-Type: text/plain; charset=&quot;us\-ascii&quot;
  Hi Kynthia,
  To recover the costs related to developing a Windows version, we have been charging a site license fee of $250 US to institutions that want to use Elena&#39;s port of
  Photosphere\.  It does appear to be stable inasmuch as we have received no complaints about its behavior from any of the licensees\.
  The long\-term goal is to port her version, which is based on the cross\-platform wxWidgets API, back to newer versions of Mac OS X and even Linux\.  Unfortunately, I
  have not had time to pursue this activity\.  I am unsure at this point when I will ever get to it\.\.\.\.
  \-Greg
  &gt; From: Chamilothori Kynthia &lt;kynthia\.chamilothori@epfl\.ch&gt;
  &gt; Date: May 30, 2016 6:09:23 AM PDT
  &gt;
  &gt; Dear Radiance community,
  &gt;
  &gt; There was a great effort a couple of years ago to create a cross\-platform version of Photosphere by Greg and Helena Eydelberg\. Is this version perhaps stable enough
  for distribution?
  &gt; Otherwise, what would you use as an alternative if not Photosphere? Has anyone used successfully any other workaround \(e\.g\. an OS X virtual box\)?
  &gt;
  &gt; Thanks for any ideas\!
  &gt;
  &gt; Best,
  &gt; Kynthia Chamilothori
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20160530/915e41c1/attachment-0001.html>
End of Radiance-general Digest, Vol 147, Issue 11
Cross-posting another relevant entry:
Subject: Re: [Radiance-general] [HDRI] Photosphere (or equivalent) in Linux or Windows?
Date: June 3, 2016 1:05:12 AM PDT
Reply-To: Majid Miri <[email protected]>, Radiance general discussion <[email protected]>
They are some tutorials for it here Aftab alpha
Majid
He Germán,
Nathaniel
Thanks, Mehlika.
I downloaded it from hdrscope - download and installed the NREL Binaries for Windows (they are working), but the setup still tells me that I need to install Radiance.
Is that a known problem? when I put "echo RAYPATH" in the command line, it returns the correct path.
Germán
Hi German,
Mehlika
      Thanks for your answer! Great to hear that the Windows port is stable and working!
      I completely understand the difficulty of continuing the porting work - thanks for all the work you have already put into this. I think that for what I want to do
      hdrgen and pcomb will do fine for now.
      Kynthia
      Message: 3
      Date: Mon, 30 May 2016 08:40:58 -0700
              Linux or Windows?
      Hi Kynthia,
      To recover the costs related to developing a Windows version, we have been charging a site license fee of $250 US to institutions that want to use Elena's port of
      Photosphere. It does appear to be stable inasmuch as we have received no complaints about its behavior from any of the licensees.
      The long-term goal is to port her version, which is based on the cross-platform wxWidgets API, back to newer versions of Mac OS X and even Linux. Unfortunately, I
      have not had time to pursue this activity. I am unsure at this point when I will ever get to it....
      > From: Chamilothori Kynthia <[email protected]>
      > Date: May 30, 2016 6:09:23 AM PDT
      > Dear Radiance community,
      > There was a great effort a couple of years ago to create a cross-platform version of Photosphere by Greg and Helena Eydelberg. Is this version perhaps stable enough
      for distribution?
      > Otherwise, what would you use as an alternative if not Photosphere? Has anyone used successfully any other workaround (e.g. an OS X virtual box)?
      > Thanks for any ideas!
      > Best,
      > Kynthia Chamilothori
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20160530/915e41c1/attachment-0001.html&gt;
I completely understand the difficulty of continuing the porting work - thanks for all the work you have already put into this. I think that for what I want to do hdrgen and pcomb will do fine for now.
Kynthia
Message: 3
  Linux or Windows?
Hi Kynthia,
To recover the costs related to developing a Windows version, we have been charging a site license fee of $250 US to institutions that want to use Elena's port of Photosphere. It does appear to be stable inasmuch as we have received no complaints about its behavior from any of the licensees.
The long-term goal is to port her version, which is based on the cross-platform wxWidgets API, back to newer versions of Mac OS X and even Linux. Unfortunately, I have not had time to pursue this activity. I am unsure at this point when I will ever get to it....
Hi German,
Mehlika
      Kynthia
      Message: 3
      � � � � Linux� �or Windows?
      Hi Kynthia,
      Photosphere.� It does appear to be stable inasmuch as we have received no complaints about its behavior from any of the licensees.
      The long-term goal is to port her version, which is based on the cross-platform wxWidgets API, back to newer versions of Mac OS X and even Linux.� Unfortunately, I
      have not had time to pursue this activity.� I am unsure at this point when I will ever get to it....
      for distribution?
      > Best,
Germán and Mehlika, thanks for introducing me to hdrscope, I’m installing it right now.
And thank you Nathaniel for solving the RAYPATH problem!
In case it helps someone else, I was using Greg’s hdrgen and the combination of ra_xyze, pcompos and pvalue to calibrate an HDR image as described in this thread<http://www.radiance-online.org/pipermail/radiance-general/2011-April/007764.html> and I ran into the following error when applying the last line:
(getinfo < capture.hdr ; echo EXPOSURE=$ecorr ; getinfo - < capture.hdr) > calibrated.hdr
The output picture reads as a ‘bad picture format’ with ximage and a closer look reveals that the EXPOSURE line that is added in the header is just above the –Y +X resolution parameters, with the empty line ("\n\n") before it, terminating the header before this new EXPOSURE variable.
Out of curiosity I put the empty line after the EXPOSURE (this time with no lines between the header variables), and now the HDR opens correctly with ximage with both EXPOSURE variables (original and new) but the luminance values are very low (<1L). I’m obviously doing something very wrong.
If I understand correctly, the error correction (and the added EXPOSURE variable) should ideally be very close to 179 based on the standard lumens/watt conversion – in my case it’s 178.02 as the ratio of measured and generated luminance values is 0.99. Is this correct?
I’ve lent our copy of Rendering with Radiance to a student, so forgive me if I’m missing things that are explained there.
Let me know if I should make a separate message about this, as I am hijacking my own thread!
Thanks for all your help,
Kynthia
From: Germán Molina Larrain [mailto:[email protected]]
Sent: samedi 4 juin 2016 01:35
Really really cool, Nathaniel. Thanks a lot.
2016-06-02 14:09 GMT-03:00 Nathaniel Jones <[email protected]<mailto:[email protected]>>:
He Germán,
Nathaniel
On Thu, Jun 2, 2016 at 12:58 PM, Germán Molina Larrain <[email protected]<mailto:[email protected]>> wrote:
Thanks, Mehlika.
Germán
2016-06-02 13:39 GMT-03:00 Mehlika Inanici <[email protected]<mailto:[email protected]>>:
Hi German,
Mehlika
2016-05-31 9:45 GMT-03:00 Chamilothori Kynthia <[email protected]<mailto:[email protected]>>:
      Kynthia
      Message: 3
      From: Greg Ward <[email protected]<mailto:[email protected]>>
      To: Radiance general discussion <[email protected]<mailto:[email protected]>>
              Linux or Windows?
      Message-ID: <[email protected]<mailto:[email protected]>>
      Hi Kynthia,
      > From: Chamilothori Kynthia <[email protected]<mailto:[email protected]>>
      for distribution?
      > Best,
Thanks for proposing a solution so quickly - much better than my clumsy attempts at grep!
However, my calibrated image still has very low luminance values (< 1.0L) This makes sense: as I read from the File Format document in the Radiance references, the EXPOSURE variables in the header are cumulative, so I am essentially dividing all my values by 178 (which is my $ecorr). Am I doing the conversion (set ecorr=`ev "179*$img_val/$meas"`) incorrectly? :slight_smile:
Thanks for your help once again,
Kynthia
Sent: mardi 7 juin 2016 17:45
Hi Kynthia,
The corrected version of this command sequence is:
            (getinfo < capture.hdr | sed 1a\
It's important to put the backslash immediately after the 'a' with no spaces for this to work. This puts the EXPOSURE= line on the second line of the header, instead of after it.
The following will create a "slighly wrong" header that will still work -- this is what I usually do:
                echo EXPOSURE=$ecorr > calibrated.hdr
                cat capture.hdr >> calibrated.hdr
Date: June 7, 2016 6:30:37 AM PDT
Germán and Mehlika, thanks for introducing me to hdrscope, I'm installing it right now.
In case it helps someone else, I was using Greg's hdrgen and the combination of ra_xyze, pcompos and pvalue to calibrate an HDR image as described in this thread<http://www.radiance-online.org/pipermail/radiance-general/2011-April/007764.html> and I ran into the following error when applying the last line:
The output picture reads as a 'bad picture format' with ximage and a closer look reveals that the EXPOSURE line that is added in the header is just above the -Y +X resolution parameters, with the empty line ("\n\n") before it, terminating the header before this new EXPOSURE variable.
Out of curiosity I put the empty line after the EXPOSURE (this time with no lines between the header variables), and now the HDR opens correctly with ximage with both EXPOSURE variables (original and new) but the luminance values are very low (<1L). I'm obviously doing something very wrong.
If I understand correctly, the error correction (and the added EXPOSURE variable) should ideally be very close to 179 based on the standard lumens/watt conversion - in my case it's 178.02 as the ratio of measured and generated luminance values is 0.99. Is this correct?
I've lent our copy of Rendering with Radiance to a student, so forgive me if I'm missing things that are explained there.
Kynthia
Hi Kynthia,
2016-05-31 9:45 GMT-03:00 Chamilothori Kynthia <[email protected] >:
working!
Kynthia
Message: 3
        Linux or Windows?
Hi Kynthia,
> Best,
URL: <
Seems relevant to this discussion as well (from Radiance-general list):
Subject: [!!SP: THIS MESSAGE IS SPAM] Re: [Radiance-general] [HDRI] Photosphere (or equivalent) in Linux or Windows?
Date: June 2, 2016 9:39:58 AM PDT
Hi German,
Mehlika
     Kynthia
     Message: 3
             Linux or Windows?
     Hi Kynthia,
     for distribution?
     > Best,
Thanks, Mehlika.
Germán
Hi German,
Radiance/lib.
Mehlika
[email protected]>:
stable and working!
      Kynthia
      Message: 3
[email protected]>
in
              Linux or Windows?
      Hi Kynthia,
      for distribution?
X virtual box)?
      > Best,
URL: <
He Germán,
Nathaniel
On Thu, Jun 2, 2016 at 12:58 PM, Germán Molina Larrain <[email protected] > wrote:
Thanks, Mehlika.
Germán
Hi German,
Radiance/lib.
Mehlika
[email protected]>:
stable and working!
      Kynthia
      Message: 3
[email protected]>
in
              Linux or Windows?
      Hi Kynthia,
      for distribution?
X virtual box)?
      > Best,
URL: <
2016-06-02 14:09 GMT-03:00 Nathaniel Jones <[email protected]>:
He Germán,
Nathaniel
On Thu, Jun 2, 2016 at 12:58 PM, Germán Molina Larrain < > [email protected]> wrote:
Thanks, Mehlika.
Germán
Hi German,
Radiance/lib.
Mehlika
[email protected]>:
stable and working!
      Kynthia
      Message: 3
[email protected]>
equivalent) in
              Linux or Windows?
      Hi Kynthia,
      for distribution?
X virtual box)?
      > Best,
URL: <
Hi Kynthia,
In case it helps someone else, I was using Greg’s hdrgen and the combination of ra_xyze, pcompos and pvalue to calibrate an HDR image as described in this thread and I ran into the following error when applying the last line:
Kynthia
Hi Kynthia,
I suppose it depends on how you obtained your $img_val. If you read it using pcomb (without -o option), then your exposure correction is correct. If you read it from ximage using the 'l' command or similar, then it was already multiplied by 179 and you should leave this factor off.
Date: June 8, 2016 4:41:37 AM PDT
Thanks for proposing a solution so quickly – much better than my clumsy attempts at grep!
Kynthia
Hi Kynthia,
Kynthia
To continue this conversation, I found a demonstration
<http://nljones.scripts.mit.edu/hdr/&gt; I made a while back of the same
source jpegs used to create HDR files with three different softwares for
Windows (Photosphere, Bracket, and Picturenaut). The page is made using a
neat little javascript export from Picturenaut. As you can see from the
histograms, the three images are nearly (but not quite) identical. As I
recall, the Photosphere image looked the smoothest in falsecolor.
Nathaniel
On Mon, May 30, 2016 at 9:09 AM, Chamilothori Kynthia < [email protected]> wrote:
Hi Nathaniel,
This is a very interesting comparison, thank you! The HDR HTML viewer looks like a great tool for sharing HDR files.
Kynthia
Sent: jeudi 9 juin 2016 02:29
To continue this conversation, I found a demonstration<http://nljones.scripts.mit.edu/hdr/> I made a while back of the same source jpegs used to create HDR files with three different softwares for Windows (Photosphere, Bracket, and Picturenaut). The page is made using a neat little javascript export from Picturenaut. As you can see from the histograms, the three images are nearly (but not quite) identical. As I recall, the Photosphere image looked the smoothest in falsecolor.
Nathaniel
On Mon, May 30, 2016 at 9:09 AM, Chamilothori Kynthia <[email protected]<mailto:[email protected]>> wrote:
I was reading it from ximage indeed - mystery solved! Thanks for the clarification.
Kynthia
Sent: mercredi 8 juin 2016 17:01
Hi Kynthia,
Kynthia
Hi Kynthia,
Kynthia
