hi,
I managed to compile it on a powerbook 1.25 G4
so the answer it's: yes it works!
my system has:
10.3.3 panther
radiance 3.5 binaries
pmap 3.28
the way I did it is:
download the archives from
http://www.ise.fhg.de/alt-aber-aktiv/radiance/photon-map/download.html
put all the archives .tar.gz in the same new directory called Test ( just a
name.. )
you decompress radiance archive (rad3R5.tar.gz) in the directory Test with
tar -xvf rad3R5.tar.gz
then there should be a new directory called ray inside Test. (I do this way
because stuffit doesn't work...)
now from the same location, inside Test, type
tar -xvf pmap-3.28.tar.gz
you should have only two .gz file and a ray directory....
now:
1 - go into ray
2 - type ./makeall install from ray
3 - select the text editor you like (pico it's my preferred)
4 - select a directory for the compiled binaries like ~/Desktop/bin (must be
created before; be carefull with permission)
5 - choose 7th option (macosX)
6 - select the library location (be carefull with permission)
7 - select your options by editing the file, if you dare ;-)) (I use
defaults...)
should be ok....
cheers,
giulio
PS sometimes I use this optimisation with G4 and radiance (not with pmap):
(you get up to 30% more)
-fast -mcpu=7450
but could be a little buggy sometimes....
[mailto:[email protected]]On Behalf Of John
An
Sent: 28 April 2004 12:49
To: [email protected]
Subject: [Radiance-general] photon-mapping on the macintosh
Could somebody with experience with using the photon-mapping extension
to radiance on a Macintosh please point me to either:
1) if it can be compiled on a Mac (I've been getting too many errors in
the compile to recount here)
2) if there is a precompiled version available for download
Thanks.
