Hi everyone,
It's me again, with new troubles... sorry for that.
I have been trying to implement the Three Phase Method on two different PCs
and two different OS, and not good news so far. Long story short, the NREL
precompiled Radiance for Windows returned only zeroes when dctimestep was
called (Andy McNeil helped me to discard syntax errors ... THANKS FOR
THAT); Ubuntu used to give me no answer, then it took turns between
"reinhart.cal not found" and some other similar things, and now it keep
throwing "segmentation fault" (my sky vector is not full of zeroes). I
already tried reinstalling my Linux distribution, compiling the Head
version (I think I did it ok), searching on the web, preinstalling x11 dev
library, and installing Learnix... but "segmentation fault" keeps there, in
the two PCs.
anyway, until now, all my compilations "have had some errors" and
dctimestep has worked some times, but I haven't been able to understand why
sometimes it works and sometimes it doesn't... I am pretty stucked here. If
there is any trick for installing RADIANCE or getting the permissions to
avoid "segmentation fault", any advice would help a lot.
THANKS
Hi Gemán,
You need to provide some information or no one can help you. What were the exact commands you used when you got your errors?
Date: December 3, 2012 5:10:55 PM HST
Hi everyone,
I have been trying to implement the Three Phase Method on two different PCs and two different OS, and not good news so far. Long story short, the NREL precompiled Radiance for Windows returned only zeroes when dctimestep was called (Andy McNeil helped me to discard syntax errors ... THANKS FOR THAT); Ubuntu used to give me no answer, then it took turns between "reinhart.cal not found" and some other similar things, and now it keep throwing "segmentation fault" (my sky vector is not full of zeroes). I already tried reinstalling my Linux distribution, compiling the Head version (I think I did it ok), searching on the web, preinstalling x11 dev library, and installing Learnix... but "segmentation fault" keeps there, in the two PCs.
anyway, until now, all my compilations "have had some errors" and dctimestep has worked some times, but I haven't been able to understand why sometimes it works and sometimes it doesn't... I am pretty stucked here. If there is any trick for installing RADIANCE or getting the permissions to avoid "segmentation fault", any advice would help a lot.
THANKS
For installing I did "sudo ./makeall install" and "sudo ./makeall library".
For the dctimestep use I did:
*dctimestep Matrices/V.vmx
Matrices/Tforward.xml Matrices/D.dmx Matrices/S.skv > results/3phase.txt*
I, of course, had a directory called Matrices where all my files were
stored. The *Tforward.xml* was generating using genBSDF on a simple clear
window, and the Daylight and View matrix were computed folowing the Andy
McNeil tutorial.
I tend to think it is a problem in the configuration of Ubuntu? I mean, the
permissions or something. But I do not know how to fix it.
2012/12/4 Greg Ward <[email protected]>
Hi Gemán,
> From: Germán Molina Larrain <[email protected]>
> Hi everyone,
the two PCs.
> THANKS
Forgot to Thank very much!
2012/12/4 Germán Molina Larrain <[email protected]>
library". For the dctimestep use I did:
McNeil tutorial.
the permissions or something. But I do not know how to fix it.
Hi Gemán,
> Hi everyone,
the two PCs.
> THANKS
Hi Germán,
You should never get a segmentation fault in Radiance, whatever you do. At this point, we should take the discussion off-list to work out what is going wrong with your compile and/or operation on Ubuntu. I will send another e-mail shortly. Do not reply to this one.
We will post a summary of what we find to the list when the issue is resolved. There may be some delays as I am presently on vacation.
Date: December 4, 2012 1:36:25 AM HST
For installing I did "sudo ./makeall install" and "sudo ./makeall library". For the dctimestep use I did:
dctimestep Matrices/V.vmx Matrices/Tforward.xml Matrices/D.dmx Matrices/S.skv > results/3phase.txt
I, of course, had a directory called Matrices where all my files were stored. The Tforward.xml was generating using genBSDF on a simple clear window, and the Daylight and View matrix were computed folowing the Andy McNeil tutorial.
I tend to think it is a problem in the configuration of Ubuntu? I mean, the permissions or something. But I do not know how to fix it.
Hi Gemán,
> Hi everyone,
> THANKS
