The XML export does pick up the tables and the format is relatively straightforward; I think you could just edit it back into tbl form, if that's what you use.
Randolph
On Nov 12, 2008, at 4:54 PM, Gregory J. Ward wrote:
Cool -- I didn't realize you could do that with Acrobat. I just tried, and it gets out the text and some of the formatting, but loses tables and things like that. Still, a starting place for the desperate...
Date: November 12, 2008 4:18:11 PM PSTThat sounds good. BTW, if you want to recover the document, I can get Acrobat Pro to export the text; I think it will even export to MS-Word or HTML-ish code.
Randolph
On Nov 11, 2008, at 3:59 PM, Gregory J. Ward wrote:
Hi Randolph,
If by Chapter 18, you mean "filefmts.pdf" from the website, then I agree. The only thing I could add are a few more header variables, but I lost the original source for this document, so editing it would be difficult.
Radiance-dev mailing list
