I’m not an expert on the pcond code, but it’s probably applying
different tone mapping depending on what it interprets as lux levels in the
scene. If you give it a scene from gendaylit -O 2, pcond doesn’t know that
the pixel value RGB triplets have already been scaled to luminance, and
thinks it’s a brighter scene, and applies a brighter tone map. If you gave
it a scene illuminated to only 10 lux of electric light, it would probably
give you a different tone mapping even if the contrast ratios were
identical.****
Can anyone else corroborate my guess?****
*Sent:* Monday, August 05, 2013 11:56 AM
*Subject:* Re: [Radiance-general] pcond, luminance or visible radiation?**
Hi, and thank you for your reply!!
If I select the output of gendaylit -O 2 (lm/m^2/sr) then I generate the
picture using rpict, convert to human visual response using pcond
-h and then to bmp using ra_bmp then I get a picture that is visually more
brighter than if I select the output of gendaylit -O 0 (default) and then
multiply by 179.
I confirm, when I use -O 2 (output lm/m^2/sr) then I don't multiply by
179, only when I select the default output (W/m^2/sr).
I don't have problem with the results of the values, but with the
generated picture, using the default of the parameter -O the picture looks
less brighter
(even after *179).
I wonder which of the two pictures is the right one, as it doesn't seem to
have anything to do with the results of the values, but with the way how
the image
is created...I guess...
I really apprecieate your help!
2013/8/5 Christopher Rush <[email protected]>****
Can you clarify the exact process when you say the picture looks less
bright? The picture out of pcond is just visually less bright? If you’re
looking at values prior to using pcond, your process to get values out of
your image is probably based on the assumption that the scene is set up
using defaults (visible W/m^2/sr). If you convert to lumens in your scene
description from gendaylit, then you have to be careful that you’re not
again converting to lumens (with a 179 multiplier) after your calculation.
*Sent:* Monday, August 05, 2013 8:13 AM
*To:* [email protected]
*Subject:* [Radiance-general] pcond, luminance or visible radiation?****
Hi all, I'd appreciate your help on the following question:****
I'm creating a radiance scene using gendaylit to generate the sky, since I
have data of the diffuse horizontal and direct normal irradiance (W/m^2)
I'm using the -W option and then -O 2 to obtain the output in lm/m^2/sr
(luminance). Then I'm using rpict to generate the picture, and pcond -h to
convert it to a human visual response.
But I realized that if I use the default value of -O in gendaylit (output
in radiance of the visible radiation W/m^2/sr) the picture looks less
bright.
So I don't know which one is the right one to use in this case.
I tried to find out if the default input when using pcond would be
luminance rather than visible radiation, but couldn't find an answer for
that, or maybe there is another command other than pcond, that takes the
input in luminance values, then that would be the one I should use. ****
Or maybe there is an additional step that I'm missing... ****
I wonder if somebody can give me a hint about this, and/or where to
look.. ![:slight_smile: :slight_smile:](https://discourse.radiance-online.org/images/emoji/twitter/slight_smile.png?v=12)
Thanks in advance!!
Ch.****
systems are scanned for acceptability of content and viruses****
http://www.radiance-online.org/mailman/listinfo/radiance-general****
