pcond: error reading from pfilt process in fovimage
Hi Mostapha,
I've noticed this issue with some images on the latest Radiance 4.2 versions as well.
Greg, the length of the file name doesn't seem to have any effect for me -- the errors remain the same. I've been ignoring the problem, so haven't traced the reason as for why it occurs, but it tends to manifest itself with Radiance images generated in certain atypical ways: (1) HDR photographs and (2) renderings using electric lighting via IES2Rad.
Here is another (very basic) rendering which has the same problem on Windows: https://dl.dropboxusercontent.com/u/3175325/pcond_error.pic
Alstan
On Mon, 20 Oct 2014 11:54:33 +0800, Greg Ward <gregoryjward@gmail.com> wrote:
I couldn't reproduce the error under MacOS X. Did you try shortening the file name?
Subject: [Radiance-general] pcond: error reading from pfilt process in fovimage
Date: October 19, 2014 10:06:12 PM CDT
Hi Radiance community,
Anybody else has issue running pcond in recent versions of Radiance? Here is the error.
I still have the older version of Radiance (4.2..a) also installed which has no problem with the same image.
Here is one of the images which fails. Cloudy sky for Denver: https://www.dropbox.com/s/f47p292vxe0ivql/>>CIE_cloudySky_sky_6_21%40900_radAnalysis_skyView.HDR?dl=0
Try pcond -h to reproduce the error.
Mostapha
it must be a Windows problem.
no problems using mac or linux (head-release 3 weeks ago).
Jan
Am 10/20/14, 5:06 AM, schrieb Mostapha Sadeghipour:
/*pcond: error reading from pfilt process in fovimage*/
Here is one of the images which fails. Cloudy sky for Denver: https://www.dropbox.com/s/f47p292vxe0ivql/CIE_cloudySky_sky_6_21%40900_radAnalysis_skyView.HDR?dl=0
Mostapha
Dr.-Ing. Jan Wienold
EPFL ENAC IA LIPID
LE 1 113 (Office)
Phone +41 21 69 38041
fyi in case anyone was trying to pipe falsecolor / gencumulativesky-generated
pics
through pfilt lately, the same error seemed to occur in this scenario - glad
it'll be cleared up :slight_smile:
~Max
Greg Ward <gregoryjward@gmail.com> hat am 20. Oktober 2014 um 15:43
geschrieben:
Well, pfilt hasn't changed in 4 years and pcond hasn't changed in 8, so my
only remaining guess is that the new way we're calling popen() under Windows
is somehow at fault. This call that was hand-written by Georg Mischler was
recently replaced under Microsoft's Visual-C compiler, and I think the issue
is that I'm not explicitly setting the binary file type in pcond. Schorsch's
win_popen() must have done this for me without my realizing it.
I have checked in the new module and it should get recompiled at some point.
My apologies, and I hope this solves the issue.
In the short term, just use the older version of pcond. It's the same,
anyway.
> From: Jan Wienold <jan.wienold@epfl.ch>
> Subject: Re: [Radiance-general] pcond: error reading from pfilt process in
> fovimage
> Date: October 20, 2014 5:02:09 AM CDT
> Hi,
> Jan
>> is the error.
>> Thanks,
>> Mostapha
I just built pond with Greg's latest checkin.
On 10/20/14, 7:43 AM, "Greg Ward" <gregoryjward@gmail.com<mailto:gregoryjward@gmail.com>> wrote:
Well, pfilt hasn't changed in 4 years and pcond hasn't changed in 8, so my only remaining guess is that the new way we're calling popen() under Windows is somehow at fault. This call that was hand-written by Georg Mischler was recently replaced under Microsoft's Visual-C compiler, and I think the issue is that I'm not explicitly setting the binary file type in pcond. Schorsch's win_popen() must have done this for me without my realizing it.
I have checked in the new module and it should get recompiled at some point. My apologies, and I hope this solves the issue.
In the short term, just use the older version of pcond. It's the same, anyway.
From: Jan Wienold <jan.wienold@epfl.ch<mailto:jan.wienold@epfl.ch>>
Subject: Re: [Radiance-general] pcond: error reading from pfilt process in fovimage
Jan
Mostapha
I'll try to reproduce the error again when in front of the work machine and let
you know- if I recall correctly I just fed a DIVA-generated HDR (from a
rpict+gencumulativesky run) to pfilt, and it wouldn't eat it. Could not figure
that one out.
m
Greg Ward <gregoryjward@gmail.com> hat am 20. Oktober 2014 um 16:35
geschrieben:
Umm... maybe not. This is specific to pcond -- I didn't find a similar
oversight in any of the other programs. Can you tell me what command(s) are
giving your errors, exactly?
Thanks!
> From: Max D <lists@spacesustainers.org>
> fovimage
> Date: October 20, 2014 9:21:21 AM CDT
> pics
> ~Max
>> geschrieben:
>> Windows
>> issue
>> Schorsch's
>> point.
>> anyway.
>> Cheers,
>> -Greg
>>> fovimage
>>> Hi,
>>> Jan
>>>> is the error.
>>>> Thanks,
>>>> Mostapha
>> _______________________________________________
