Thanks for the quick response Greg!
I'm using a specific, specular reflective color on each facade orientation
of a building to better understand which curtain wall orientation is
contributing to direct solar reflections on the street level. I'm trying to
parse from each image in an annual, time lapse series the resultant
patterns of reflection on the street separately for each orientation /
color.
Running the script you sent I'm getting the following error:
is_yellow: undefined function
Thanks again,
Chris
Christian Humann ~ Associate
*LOISOS *+* UBBELOHDE*
Alameda, CA 94501 USA
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com
On Jan 16, 2013, at 11:08 AM, Greg Ward wrote:
Hi Chris,
I'm not sure I understand what you're after, exactly. The following will
turn all pixels black except those with a nearly-zero blue channel and
non-zero red and green channels:
pcomb -e 'and(a,b):if(a,b,a)' -e
'ypix=and(.01*ri(1)-bi(1),.01*gi(1)-bi(1))' -e
'ypix=is_yellow(ri(1),gi(1),bi(1))' \
-e 'ro=if(ypix,1,0);go=if(ypix,1,0);bo=0' input.hdr > output.hdr
The and() expression returns positive if both red and green channels are
more than 100 times the blue channel. We can't compare blue to zero due to
limitations in the accuracy of RGBE pixel values.
*Date: *January 16, 2013 10:47:38 AM PST
Dear group,
I would like to use 'pcomb' to clip yellow reflections (r,g,b=1,1,0)
coming off of the same colored mirrored glass on a facade system and write
to a new image such that only these reflections are shown. I thought I'd
pestered the group enough times on 'pcomb' matters to figure this out using
the many great responses I've received over the years, but the right syntax
is eluding me now.
As always,
Thanks!!
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com
