Using pcomb this way, the resulting image has higher radiance values as the input images. What I want is that the resulting image has the same radiance values as the input files. How can I do that?
You'll need to adjust the scale factor based on the number of images (of course). If you care about the absolute values and exposures have been applied to your image, you should add a "-o" option before each input file as well.
Date: October 6, 2012 12:15:24 PM PDT
I have a couple of Radiance images which are almost the same. These images are combined using pcomb:
