pcomb error
Dear list,
I am trying to use a pcomb syntax from an earlier post for vignetting
correction (using the polynomial y = -9E-09x5 + 1E-06x4 - 4E-05x3 -
0.0003x2- 0.0637x + 21.223
pcomb -e 'sq(x):x*x;r=sqrt(sq(2/xres*x-1)+sq(2/yres*y-1))' \ -e
'sf=-9E-09*r^5 + 1E-06*r^4 - 4E-05*r^3 - 0.0003*r^2 - 0.0637*r + 21.223' \
-e 'ro=sf*ri(1);go=sf*gi(1);bo=sf*bi(1)' fisheye_28.hdr > corrected.hdr
I am getting "no such file or directory" error. Still, pcomb writes a 65kb
output file with the name I defined. First I thought it could be a problem
related to the path or installation so I tried to run including the full
path of both input and output images but got the same result.
I also tried the command on a Mac and got the same error. I checked the
path on the Mac and it seems correct. Environmental variables and registry
entries look ok on the windows machine, too. Every other command seem to
work fine.
Am I missing something in the syntax?
Thank you,
Alp
Hi
there is a backslash in your commandline. Probably you copied it from a script, where it was inserted to continue the command on the next line. However, in your case, it will cause the error message you describe.
pcomb -e 'sq(x):x*x;r=sqrt(sq(2/xres*x-1)+sq(2/yres*y-1))' -e 'sf=-9E-09*r^5 + 1E-06*r^4 - 4E-05*r^3 - 0.0003*r^2 - 0.0637*r + 21.223' -e 'ro=sf*ri(1);go=sf*gi(1);bo=sf*bi(1)' fisheye_28.hdr > corrected.hdr
(all in one line) should do the job.
Cheers & iyi calismalar,
Lars.
Dear list,
I am trying to use a pcomb syntax from an earlier post for vignetting correction (using the polynomial y = -9E-09x5 + 1E-06x4 - 4E-05x3 - 0.0003x2 - 0.0637x + 21.223):
pcomb -e 'sq(x):x*x;r=sqrt(sq(2/xres*x-1)+sq(2/yres*y-1))' \ -e 'sf=-9E-09*r^5 + 1E-06*r^4 - 4E-05*r^3 - 0.0003*r^2 - 0.0637*r + 21.223' \ -e 'ro=sf*ri(1);go=sf*gi(1);bo=sf*bi(1)' fisheye_28.hdr > corrected.hdr
I am getting "no such file or directory" error. Still, pcomb writes a 65kb output file with the name I defined. First I thought it could be a problem related to the path or installation so I tried to run including the full path of both input and output images but got the same result.
I also tried the command on a Mac and got the same error. I checked the path on the Mac and it seems correct. Environmental variables and registry entries look ok on the windows machine, too. Every other command seem to work fine.
Thank you,
Alp
Hello Lars,
Thank you. Yes, removing the brackets did the job.
Alp
On Fri, Jan 25, 2013 at 12:00 PM, <[email protected]> wrote:
Send HDRI mailing list submissions to
than "Re: Contents of HDRI digest..."
Today's Topics:
   1. pcomb error (Mehmedalp Tural)
   2. Re: pcomb error (Lars O. Grobe)
Message: 1
Date: Thu, 24 Jan 2013 19:17:18 -0800
Subject: [HDRI] pcomb error
Message-ID:
CACu+U4biScb2pcHELMvzd869CyZA-GmkQU_Ec00TiY5nOG7jkw@mail.gmail.com>
Dear list,
work fine.
Thank you,
Alp
URL: <
http://www.radiance-online.org/pipermail/hdri/attachments/20130124/488c3030/attachment-0001.html
Message: 2
Date: Fri, 25 Jan 2013 12:15:10 +0800
To: High Dynamic Range Imaging <[email protected]>
Subject: Re: [HDRI] pcomb error
Hi
Lars.
> Dear list,
work fine.
> Thank you,
> Alp
URL: <
http://www.radiance-online.org/pipermail/hdri/attachments/20130125/37e5bb14/attachment-0001.html
HDRI mailing list
End of HDRI Digest, Vol 55, Issue 1
