Partial Mirror Modelling
Is it possible to model a partial mirror in Radiance?
That is, a surface that reflects say 50% of light as a mirror and lets 50% pass through?
Thanks
you can use mixfunc and mix the mirror material with “air” (air can be modeled by glass with refraction index 1). You can use a static mixture (e.g.0.5) or a cal-file defining this fraction by angle of incidence.
hope that helps
Jan
You can also use the “trans” type if you don’t care to model any Fresnel effects. (I.e., you are OK with constant transmission & reflection at all incident angles, which is not the way a real half-silvered mirror behaves.)
