Dear all,
A question regarding the orientation of glazing in three- and five-phase calc.
When calculating the view matrix, I know the glazing aperture should facing towards the interior. Should I flip the orientation of the glazing aperture towards the exterior when calculating the daylight matrix? I see the Matrix-based tutorial did not do that, but an answer to a past question in the mailist said "yes".
Tommy
Minchen (Tommy) Wei, PhD
The Hong Kong Polytechnic University
(+852)-3400 3606 [email protected]<mailto:[email protected]>
[http://mlm.polyu.edu.hk/PolyU_Email_Signature.jpg]
Disclaimer:
This message (including any attachments) contains confidential information intended for a specific individual and purpose. If you are not the intended recipient, you should delete this message and notify the sender and The Hong Kong Polytechnic University (the University) immediately. Any disclosure, copying, or distribution of this message, or the taking of any action based on it, is strictly prohibited and may be unlawful.
The University specifically denies any responsibility for the accuracy or quality of information obtained through University E-mail Facilities. Any views and opinions expressed are only those of the author(s) and do not necessarily represent those of the University and the University accepts no liability whatsoever for any losses or damages incurred or caused to any party as a result of the use of such information.
I do not believe that you should flip the window orientation in the 5-phase method.
Date: March 24, 2018 6:11:24 AM PDT
Dear all,
When calculating the view matrix, I know the glazing aperture should facing towards the interior. Should I flip the orientation of the glazing aperture towards the exterior when calculating the daylight matrix? I see the Matrix-based tutorial did not do that, but an answer to a past question in the mailist said “yes”.
Tommy
Dear Minchen,
as a follow-up on that - you should definitely not flip the surface if you
are using rfluxmtx to calculate your matrices. Quoting from the manpage:
"Rays always emanate from the back side of the sender surface and arrive at
the front side of receiver surfaces. In this way, a receiver surface may be
reused as a sender in a subsequent rfluxmtx calculation and the resulting
matrices will concatenate properly."
David
2018-03-24 17:38 GMT+01:00 Greg Ward <[email protected]>:
5-phase method.
*Date: *March 24, 2018 6:11:24 AM PDT
Dear all,
calc.
Tommy
*Minchen (Tommy) Wei, PhD*
(+852)-3400 3606 <+852%203400%203606> [email protected]
