I am a student in Vienna and working on a daylight simulation with pipeflow: IDGB#optics6#window7.2#ecotect2011#grasshopper#radiance#daysim3.1
Asking with un unease, since you must also have a tight schedule, still I need to post two question:
Could someone , please, make a break down of the steps creating double glazing material with coating for Radiance?
After generating the *.rad files from optics do you manually correct the material in Radiance editor?
How do I implement optics2glaze with the glaze script for achieving this?
here is one of the glazing systems:
1st layer: pane 4mm
PVB coating 0.78mm 6mm glass pane#cool lite skn 174 22mm Argon 90% 2nd pane : 4mmTn = 64% (IGDB source)
Manufacturer value of the system
Tn=68% R(outside)=13% R(inside)=11%
For my understanding tried to compare some values from manufacturer with my Window output - and the discrepancy is quite generous. The PVB is missing, though.
How would you proceed when you solve this problem elegantly? ATTACHED : the materials of the whole double insulated glazing system#output window7.2
the single glass pane materials#output opitcs6
Any comments are highly appreciated.
Kind Regards from Vienna, Niya
0_cool_lite174_4_6_4.rad (654 Bytes)
COOL-LITE_SKN_coatingfront_174_6mm.rad (733 Bytes)
PLANILUX_4.rad (650 Bytes)
