Hey everyone,
I’ve been experimenting with the oconv settings to try and cut down the time it takes to generate an octree. It seems like two settings, -n and -r, are key factors here.
1) With default settings - 60s: When I leave -n and -r at their default (which I believe are 6 and 16384, respectively), it takes a minute to create the octree.
2) Adjusted for my scene - 79s: Based on the maximum distance and minimum spacing in my scene, I calculated that -r should be around 566. Surprisingly, this actually led to an increase in octree generation time.
3) Trying different values - 77s: I then tried setting -n to 1000 and -r to 16, thinking this might speed things up. However, the generation time was still longer than with the default settings.
I was under the impression that increasing -n and decreasing -r would make the octree generation faster. What am I overlooking here?
Alex
P.S. I’m aware that changes in octree resolution can affect rtrace’s runtime and precision, but that’s not my focus at the moment.
