I have a question regarding the obj2mesh tool. So far I always used
instances generated by oconv, and the -r setting was always the one that I
also used when assembling the whole scene (the same with -n). Now I use
obj2mesh, and a question comes to my mind. If I follow the rule -r >
bounding cube / smallest face, I can use a much smaller -r for obj2mesh then
for the finally assembling oconv. However, does that make sense? Or will I
produce trouble with differing resolution settings for instances, meshes and
the complete scene?
The reason for my question is that the model I am working on is currently
growing a lot, and I a getting trouble with really large oconv processes
when assembling the scene ( > 1 GB) or, when using the -n parameter, slow
renderings...
TIA+CU Lars.
Hi Lars,
If I understand your question correctly, you do not need to worry about the difference between the minimum voxel size set by -r in obj2mesh and the minimum voxel set in oconv, as they are unrelated. Oconv incorporates the mesh created by obj2mesh, as well as instances created by other oconv runs, as transformed cubes in the scene, and does not subdivide them beyond that unless they intersect other instances or meshes or geometry. If they intersect each other too much, oconv can take a long time to resolve them.
Date: May 16, 2005 5:51:39 AM PDT
the complete scene?
renderings...
TIA+CU Lars.
