Has anyone seen these when trying to convert Rhino OBJ exports? What do they mean?
Radiance 4.0 / Rhino Mac 4.0 WIP
Randolph
Randolph
One of the things they seem to mean is "Clean up your Rhino model." Another thing they probably mean is "Don't rely on WIP software." But it would be nice to know a bit more for the future.
Randolph
Dear Randolph,
I have encountered this before with a complex Rhino model as well. Luckily OBJ files are plain text.
In my case, a few of the points in my obj file were given a normal of 0 0 0 which obj2rad did not like. I fixed it by running a find and replace on "vn 0 0 0" with "vn 0 0 1" without any negative consequences.
The specific errors of bad face or triangle seem to come from bad vt (vertex texture-coordinate) data in your OBJ file, so I would start by looking there.
Best regards,
Alstan
...but it came back for a sequel.
The following example OBJ file fails with "bad face:"
g OFFICE_POSTER
v 6.026500225067139 94.81300354003906 288.5
v 6.026500225067139 94.81300354003906 244.4450073242188
v 6.026500225067139 144.3130035400391 244.4450073242188
v 6.026500225067139 144.3130035400391 288.5
vn 1 0 0
f 1//1 2//2 3//3 4//4
It's a rectangular face in the Y-Z plane, the vertices are ordered counter-clockwise, and the vertex normals are pointing in the X direction. Reversing the vertex directions makes it go. It looks right to me, but I wonder if I'm confused about clockwise & counterclockwise.
Ah, well. To be continued tomorrow.
Randolph
Dear Randolph,
Best regards,
Alstan
Hello:
You may also try "mesh" -"mesh repair tools"-"rebuild mesh normals "
Jia
On Tue, Sep 21, 2010 at 5:03 PM, Randolph M. Fritz <[email protected]> wrote:
g OFFICE_POSTER
vn 1 0 0
vn 1 0 0
vn 1 0 0
vn 1 0 0
f 1//1 2//2 3//3 4//4It's a rectangular face in the Y-Z plane, the vertices are ordered
wonder if I'm confused about clockwise & counterclockwise.Ah, well. To be continued tomorrow.
Randolph
they mean?Dear Randolph,
OBJ files are plain text.In my case, a few of the points in my obj file were given a normal of 0 0
"vn 0 0 0" with "vn 0 0 1" without any negative consequences.The specific errors of bad face or triangle seem to come from bad vt
looking there.Best regards,
Alstan_______________________________________________
Good idea. I've been using the automatic meshing of Rhino export, which I expect to produce correct models, but if I manually meshed the model, that might help--maybe I'll try it.
Randolph
Hi Randolph,
I ran your OBJ snippet through the HEAD version of obj2rad, and it didn't complain. I made some recent changes at the request of Jack de Valpine.
Date: September 22, 2010 2:54:35 PM PDTOn 2010-09-22 11:19:36 -0700, Jia Hu said:
Randolph
Hi Randolph,
Greg added a feature to obj2rad to enable it to continue in the case of bad normals such as: vn 0 0 0. Previously obj2rad would exit with an error.
Backing up a bit, I think what I am interested in seeing is conversion tools that further support .obj as an intermediate file format for Radiance. There are lots of good applications (Rhino, SketchUp Pro, Blender, etc) that support export of .obj format files. And for those applications that do not (eg, Autocad and Revit), one route is that it is possible to get .fbx out of these applications which can then be converted to .obj. However the data output from these applications is not always perfect, which results in obj2rad exiting with errors relating to: bad normals, bad faces and bad triangles. So the issue is what to do in these cases:
1. bad normals (vn 0 0 0) - are now passed through using the updated
version of obj2rad from the head release.
2. bad faces and bad triangles - In some case this is something that
can be fixed in an application like Rhino or Blender (these are
the ones that I know) using the repair mesh functionality.
However, I have also noted that the following can sometimes be
included by the exporting application: #QNAN0 or #IND. This is
easy to check for using grep. Typically I have seen this:
-1.#QNAN0 or -1.#IND. Since these errors occur upstream from
obj2rad, Greg is rightly loathe to have ob2rad try to fix them. If
you cannot fixes these in the upstream application, then the easy
fix in these cases is to use sed or perl to zero out these
conditions. This can be done as follows (pick your tool):
1. perl -p -e 's/\#QNAN0/0/g;s/\#IND/0/g' fname.obj | obj2rad >
fname.rad
2. sed 's/\#QNAN0/0/g;s/\#IND/0/g' fname.obj | obj2rad > fname.rad
If anyone has other suggestions for managing and processing .obj files for use in Radiance please chime in! I know that Mark Stock has had good experience with MeshLab, for example.
# Jack de Valpine
On 9/27/2010 5:48 PM, Greg Ward wrote:
Hi Randolph,
-GregFrom: "Randolph M. Fritz"<[email protected]>
Randolph_______________________________________________
Thanks, folks. I'm beginning to think I misunderstand the use of "void" in obj2rad.
The following OBJ file:
g OFFICE_DOOR_JAMB_A
o object_23
v 2.500880479812622 10.49974822998047 192
v 3.500880241394043 10.49974822998047 192
v 2.500880479812622 10.49974822998047 231.9999847412109
vt 0.200000062584877 0
vt 0.212481752038002 0
vt 0.200000062584877 0.499267578125
vn 0 -1 0
f 1/1/1 2/2/2 3/3/3
And the following mapping file:
void (Group "OFFICE_DOOR_JAMB_A");
produces a "bad triangle" error.
If I change "void" to "wood," obj2rad succeeds.
Say, what?
At least, I think I have workarounds.
Randolph
So I got rid of the "void"s, and found another apparently good face which draws the "Bad Triangle" message.
It's a very long file--the error occurs at line 12104. So far I have not been able to construct a short example; the same face are accepted without complaint. If I don't use a mapping file, the conversion runs without incident. This is beginning to look like an obj2rad bug.
Anyone have a workaround to suggest? Also, anyone actually used a debugger with obj2rad?
Randolph
Thanks, Randolph. This was a bug. Obj2rad is supposed to quietly elide surfaces that map to the "void" type, but this has been broken, perhaps from the beginning. I just checked a fixed version into CVS.
Date: September 28, 2010 12:46:39 PM PDTThanks, folks. I'm beginning to think I misunderstand the use of "void" in obj2rad.
o object_23
vn 0 -1 0
vn 0 -1 0
vn 0 -1 0
f 1/1/1 2/2/2 3/3/3And the following mapping file:
Say, what?
Randolph
Thanks very very much for the prompt fix, Greg. This also fixed my second bug, which involved a surface which had no assigned material type and was therefore treated like "void", triggering the bug.
Randolph
o object_23
vn 0 -1 0
Say, what?
Randolph
Randolph
