mosaic with mixpict?
Lars O. Grobe wrote:
So the question is still if I can use a mixpict-modified material
as background in a mixpict modifier's definition, some kind of nested
mixpict modifier.
You can nest mixpicts (and almost anything) recursively as often
as you want. On the other hand, why don't you just use a picture
of your mosaic and map that on the surface as a normal colorpict?
-schorsch
Hi!
Because (again, I had to explain that in a different thread before) I have material values for the stones the mosaic is made of, but no calibrated picture of the whole that I could simply use as a colorpict. However, I can "draw" the mosaic using the known values, than map that drawing. However, as I never used the mixpict, which seams to be a quite powerful tool, I was quite interested in its limitations, and I found very few documentation on it.
So thank you all who answered, I got an idea now what I can do with that mod, CU, Lars.
Lars O. Grobe
