Modellling light pipes / light tubes
I'll like to model the effect of light pipes in a two storey building.
These pipes would enter through the roof via a half-dome of glass. A
highly reflective pipe (approximately 400mm diameter) runs from this
roof to the ground floor's ceiling where it strikes a diffuser and
lights the space below.
The obvious way to model this would be a vertical cylinder with a highly
reflective surface inside. Probably the top surface (where the light
comes in) should be an illum surface. I'm not sure, however, that this
method would be very efficient or accurate.
What's the best way to model these light pipes? Has anyone done a
similar thing?
Brett
Brett Beeson
Sustainable Designer
CUNDALL
HSBC Building Level 20
300 Queen Street
Brisbane QLD 4000
tel: +61 (0)7 3023 5048
fax: +61 (0)7 3023 4000
www.cundall.com.au <http://www.cundall.com.au/>
Important Notice. Use of this email and any attachments is subject to
the terms on www.cundall.com.au.
Please read that notice before proceeding.
If you cannot access these terms please telephone (02) 8424 7000 or
reply to this email and we will send you a copy.
Brett,
You really need a forward raytracer to model light-pipes. Do this search in Google:
site:www.radiance-online.org "light pipe"
to find the previous discussions on light pipes and related.
-John
Dr. John Mardaljevic
Senior Research Fellow
De Montfort University
The Gateway
Leicester
LE1 9BH, UK
+44 (0) 116 257 7972
+44 (0) 116 257 7981 (fax)
http://www.iesd.dmu.ac.uk/~jm
Hi Brett,
I hesitate to suggest it, because I don't know exactly how (or even if) it would work, but the new rtcontrib program is meant to solve just this sort of problem. If you are feeling adventurous, check it out.
Date: November 27, 2005 3:01:24 PM PST
I’ll like to model the effect of light pipes in a two storey building. These pipes would enter through the roof via a half-dome of glass. A highly reflective pipe (approximately 400mm diameter) runs from this roof to the ground floor’s ceiling where it strikes a diffuser and lights the space below.
The obvious way to model this would be a vertical cylinder with a highly reflective surface inside. Probably the top surface (where the light comes in) should be an illum surface. I’m not sure, however, that this method would be very efficient or accurate.
What’s the best way to model these light pipes? Has anyone done a similar thing?
Brett
