Ehsan,
If you check the "perezlum.cal" file, you will see what the 10 values are:
* All-weather Angular Sky Luminance Distribution .*
* Additional arguments required for calculation of skybright:*
* A1 - diffus normalization*
* A2 - ground brightness*
* A3,A4,A5,A6,A7 - coefficients for the Perez model*
* A8,A9,A10 - sun direction*
Regarding your second question about why do we need to add the glow source;
that is because the material created by "gendaylit" or "gensky" is actually
a modifier. That modifier is what gives the sky semi-hemisphere and the
ground semi-hemisphere the correct luminance for each angle, representing
different sky models.
Why does not the program just write the Glow Source as well? No idea...
I hope it helps!
German
2014-04-07 14:03 GMT-03:00 Ehsan M.Vazifeh <[email protected]>:
Dear Lars,
As I understood correctly I have just distribution of diffuse using sky
scanner. So I need to include the sun separately. Now I have two questions:
1) what is 10 real arguments in the sky scene generated by gendaylit
(below you will find the example)
void brightfunc skyfunc
2 skybright perezlum.cal
10 3.114e+01 2.426e+01 -0.989445 -0.210729 22.988
-5.9264 1.398847 -0.010398 -0.415479 0.909543
2) why when we generate a sky for instance with sun description, we should
always include the sky scene as a glowing source otherwise the illuminance
values will be zero.
I guess I have some fundamental misunderstanding about the sky scene
description. It would be real help if I can get some explanation why this
happens.
CHeers,
Ehsan
On Mon, Apr 7, 2014 at 11:05 AM, Lars O. Grobe <[email protected]> wrote:
Hi Ehsan,
as far as I understand the scan pattern used by the scanner is close
enough to the Tregenza patches to use it with dctimestep and daylight
coefficients. To get an idea of the format expected by that tool, have a
look at the output of gendaylit.
Be aware that the sun is excluded in the measurements, so you will have
to find a way to get the direct sun contribution. As there are no "color
channels" in the measurement, you would use the luminance readings and
apply them to all three channels in Radiance equally (R=G=B).
Dear All,
I try to model sky and daylight using measured data from sky scanner.
I want to know is it possible to convert radiance or luminance of each
patch to rgb and use 145 primitive of type source to model the sky? or my
assumptions are wrong?
Ehsan
*Germán Molina L.*
Ingeniero Trainee
Hunter Douglas Chile S.A.
Celular +569 89224445
gracias.
