OK, this helps. What you probably want to do is compute the average
behavior as a BSDF, which requires explicitly modeling a small section of
the material. You can do this using antimatter to get the holes perfectly
cylindrical. Start with a slab from genbox as you suggested, then use
antimatter like so:
void metal aluminum
5 0.7 0.7 0.7 0.9 0.02
!genbox aluminum slab 140 140 4 | xform -t 0 0 -4.01
void antimatter hole_mat
1 aluminum
!xform -n even -t 10 10 0 -a 10 -t 12 0 0 -a 6 -t 0 20.78461 0 cylinder.rad
!xform -n odd -t 16 20.392305 0 -a 10 -t 12 0 0 -a 6 -t 0 20.78461 0
cylinder.rad
The file "cylinder.rad" contains:
hole_mat ring cyl.top
8
0 0 0
0 0 1
0 4
hole_mat cylinder cyl
7
0 0 0
0 0 -4.02
4
hole_mat ring cyl.bot
8
0 0 -4.02
0 0 -1
0 4
You then need to run genBSDF on the whole thing, keeping your sampling
region within the appropriate zone:
genBSDF -t4 5 +geom millimeter +f +b -dim 10 70 10 72.35383 -4.02 0
perf.rad > perf.xml
This creates a tensor tree, which is probably better for this material.
If you need a Klems matrix, just leave off the "-t4 5" setting.
To apply the resulting XML file in a model, you can put this in your
rendering file:
void BSDF perf_mat
6 0 perf.xml 0 1 0 .
perf_mat polygon perf_shelf
12
{coordinates in horizontal plane with normal aligned with Z}
I hope this works for you. If you need the shelf to have a different
alignment, just change the "up" orientation for the BSDF (set to XYZ == 0 1
0 in the above example).
*Subject: *Re: [Radiance-general] modelling perforated materials
*Date: *July 21, 2015 9:23:04 PM PDT
Greg,
The spec at the moment is 4mm thick aluminium with 8mm diameter holes at
12mm pitch in a hexagonal pattern. The open area is 40%. The viewing
position is at a distance, so correct average behaviour might work, however
I am relying on the inside surface of the holes to reflect light to the
viewer, so I’m not sure how using a trans material or suchlike would work
in this case. The plan was to render one panel to show effect of being
internally when veiwed from below on ground level.
John.
(may be duplicated- replied from wrong address)
On 22 Jul 2015, at 1:51 pm, Greg Ward <gregoryjward@gmail.com> wrote:
Hi John,
How big are the holes relative to the thickness of the material? What
percentage of "holiness" does the surface possess, on average? Are the
wholes aligned in a grid or a hexagonal pattern? Are you going to be in a
rendering position where you actually see the holes, or do you just want
the correct average behavior with a minimum of noise?
Subject: [Radiance-general] modelling perforated materials
Date: July 21, 2015 8:35:44 PM PDT
I’m trying to find the best way to model a perforated aluminium panel and
struggling with antimatter materials and such like. Could someone please
advise how to do this without ending up with a massive number of surfaces?
I haven’t found many examples of how to use the antimatter material apart
from the glass lotus in Rendering with Radiance.
My initial assumption was that the panel should be made with genbox then
an array of antimatter holes should be added using cylinders of antimatter
material, slightly longer than the thickness of the panel. Would it also be
possible to genbox the panel then insert tubes into it or would the face of
the panel still be present?
John Ford.
