I am a relative newcomer to Radiance, so please forgive my ignorance.
I am interested in simulating a room with a deep lightwell as the only
source. The top of the light well has a double glazed skylight and the
bottom of the lightwell is an as-yet undefined product that produces
diffuse light and has a very high visible light transmittance. My
questions are:
1. Will a light frit or white paint coating on glass transmit highly
diffused light? If not, any products to recommend that will?
2. Will Lamberts cosine law be a reasonable estimate for the BTDF and
BRDF? And what are reasonable peak (zero angle) values to expect?
3. Am I going to run into problems with Radiance finding the light
source? Which inputs will help Radiance find the light?
Thanks for any guidance.
______________________________________________________________
Celebrating Excellence Since 1972. For more information, please visit www.rwdi.com/35th_anniversary/.
Reputation Resources Results
http://www.rwdi.com
This communication is intended for the sole use of the party to whom it is addressed and may contain information that is privileged and/or confidential. Any other distribution, copying or disclosure is strictly prohibited. If you have received this e-mail in error, please notify us immediately by telephone and delete the message without retaining any hard or electronic copies of same.
RWDI scans outgoing emails for viruses, but makes no warranty as to their absence in this email or attachments.
Hi Derek,
I didn't see any responses to this query, so I guess it fell through the cracks. Sorry about that. Some quick, feeble answers:
1. Certain frits will transmit diffuse light, though imperfectly. Note that an ideal diffuser will transmit 50% of the light and reflect the other 50%. To transmit more than 50% of the light, you will necessarily deviate from a Lambertian (diffuse) distribution.
2. If you choose a dense enough frit for Lambertian diffusion, then a diffuse transmission/reflection model will suffice by definition. A reasonable diffuse transmission to expect is around 40% for a good quality frit, and about the same for refleciton.
3. You will run into problems if you don't use the mkillum command and manually identify your sources. See the basic tutorials in "Rendering with Radiance" on appropriate application.
Date: July 11, 2007 6:35:17 PM PDT
questions are:
