Hello Radiance Experts,
I want to model an LED monitor with a measured beam pattern. Also, I want to superimpose an image on the monitor such that the light projected through the image is affected by the monitor's beam pattern.
I'm running into trouble with my current procedure (INCORRECT IMAGE COLORS - TOP IMAGE), it produces a monitor image that appears to be color inverted, also the image surface has 0 radiance even though it is applied to a light primitive that has a radiance definition.
See top display image doesn't look like the bottom one, also the top image has no light output: https://s31.postimg.org/8cal8he6j/Monitor_Dif.png
******* INCORRECT IMAGE COLORS - TOP IMAGE ********
void brightdata Monitor_BeamPattern
5 flatcorr Mockup_Lamp_BeamPattern.dat source.cal src_theta src_phi
1 1
Monitor_BeamPattern colorpict monitor_image2
9 clip_r clip_g clip_b Image.hdr picture.cal pic_u pic_v -s 0.254
monitor_image2 light monitor2_background
3 10 10 10
monitor2_background polygon monitor_surface2
12
0 0 0
0.444 0 0
0.444 0.254 0
0 0.254 0
******* CORRECT IMAGE COLORS BUT NO BEAM PATTERN - BOTTOM IMAGE ********
void colorpict monitor_image3
monitor_image3 light monitor3_background
3 10 10 10
monitor3_background polygon monitor_surface3
12
0 0 0
0.444 0 0
0.444 0.254 0
0 0.254 0
Why is the top definition, using brightdata, produce a color distorted image, that has no luminance? Advice on modelling a monitor will be much appreciated!
Thank you for your time,
Andrei Kolomenski
