Today's Topics:
1. Re: oconv and rtrace_dc warnings for non-planar vertices
(Thomas Bleicher)
2. Re: oconv and rtrace_dc warnings for non-planar vertices
(Greg Ward)
3. Re: Modeling Question for Translucent Glass (Thomas Bleicher)
4. RE: Modeling Question for Translucent Glass (Christopher Rush)
5. Re: Modeling Question for Translucent Glass (Greg Ward)
---------- Forwarded message ----------
Date: Thu, 12 Jun 2008 20:16:05 +0100
Subject: Re: [Radiance-general] oconv and rtrace_dc warnings for non-planar
vertices
On 11 Jun 2008, at 21:24, Ramana Koti wrote:
oconv: warning - non-planar verterx for polygon "f_1719_0" (this happens
for 20 or so polygons)
rtrace_dc: warning - non-planar vertex for polygon "F_1636 (Can't see the
rest of it, this happens for probably the same polygons but not in the same
order)
I used the SketchUp to Radiance su2rad plugin to export geometry from a
sketchup model and I had to start the simulation before DAYSIM refreshed
geometry display since it was taking too long to do that.
How serious are these warnings and why are they occuring?
The export of polygons from Sketchup has only a limited accuracy. This
results in some
cases in polygons where one of the points is outside of the plane defined
by the rest
of the vertices. Radiance has a built in tolerance for these points but
when that's exceeded
the warning is generated and the vertex or the whole polygon ignored in the
rendering.
I'm not sure about the last part but maybe someone else knows better.
Relevance: If the polygon is ignored and it is essential for the geometry
(ie a wall of a room)
then it is relevant. If it's just a tiny piece that doesn't do much for the
lighting it's harmless.
To avoid this problem export with the option 'triangulate'. This creates
polygons with
only 3 vertices. Much more polygons in the scene but no warnings.
Date: Thu, 12 Jun 2008 14:40:22 -0700
vertices
The warnings don't indicate any action, and are only given by Radiance
because cracks may appear between polygons due to the determination of an
"average plane" that doesn't pass exactly through every point.
Date: June 12, 2008 12:16:05 PM PDT
order)
results in some
by the rest
the rendering.
the lighting it's harmless.
polygons with
Date: Thu, 12 Jun 2008 23:03:00 +0100
Subject: Re: [Radiance-general] Modeling Question for Translucent Glass
On 12 Jun 2008, at 17:50, Nikhil Kapur wrote:
I am fairly new to Radiance and was trying to model a interior translucent
glazing
void trans translucent panel
7 1 1 1 0 0 0.5 0.2
One obvious error is the name 'translucent panel'. Identifiers can not
contain
spaces so it should be 'translucent_panel' or something like that.
The '1 1 1' looks odd to me. I don't think that's actually a physical
material.
I'd go for something like 0.8 for white.
The second issue which I have not been able to figure out is how to show
this trans material inside the space in the final rendering in Radiance as
it is essentially invisible.
Think about it:
if it's 50% translucent it has to be visible (even glass with 50%
transmission would
show as a darker shade of the room behind it.) You're talking about 'white'
so I assume
that you do want some amount of scattering of the light. In fact, the
material above
scatters 80% of the light that passes, so it would definitely be visible.
Just try a simple scene with a test cube and a bit of ground below and use
the command 'objview' (Unix only) to see how the material works out.
Date: Thu, 12 Jun 2008 18:16:22 -0400
Subject: RE: [Radiance-general] Modeling Question for Translucent Glass
A thought about rendering as "invisible" ..
Nik, Is it invisible in any rendering, or only if you render an illuminance
image with the -i option?
[email protected]] *On Behalf Of *Thomas
Bleicher
*Sent:* Thursday, 12 June, 2008 6:03 PM
*Subject:* Re: [Radiance-general] Modeling Question for Translucent Glass
translucent glazing
7 1 1 1 0 0 0.5 0.2
contain
material.
Think about it:
transmission would
so I assume
material above
To: "Nikhil Kapur" <[email protected]>
Date: Thu, 12 Jun 2008 15:35:38 -0700
Subject: [Radiance-general] Re: Modeling Question for Translucent Glass
Hi Nikhil,
As Thomas said in his response, the material should show up in a normal
rendering. The best way to model frit glass is to use the "glaze.csh"
script that I created with funding from Visarc. For a single-pane glazing
using a full covering of V-175 white frit, this script produces:
# Glazing produced by Radiance glaze script
# Revision: 2\.7
# Material surface normal points to interior
# Number of panes in system: 1
# Exterior surface s1 type: clear glass
# Interior surface s2 type: V-175 white frit
# s2 coating coverage: 1
# Exterior normal hemispherical reflectance: 0.33
# Interior normal hemispherical reflectance: 0.59
# Normal hemispherical transmittance: 0.21
void BRTDfunc glaze1_unnamed
10
sr_frit_r sr_frit_g sr_frit_b
st_frit_r st_frit_g st_frit_b
0 0 0
glaze1.cal
11
0.59
0.59
0.59
0.256
0.253
0.251
0.21
0.21
0.21
-1 1
Try this for now, or run the script yourself to vary the parameters. If
you can't run the script because you only have a Windows machine, then you
may be stuck playing around with the "trans" material.
Date: June 12, 2008 3:14:17 PM PDT
I had a question for modeling in Radiance. I apologize for emailing to you
directly. I have posted it on the radiance forum today morning as well, but
had not seen any responses and I have a deadline to meet.
Since I am fairly new to Radiance I was trying to model an interior
translucent glazing (possibly a frit on the glazing). I looked up the
archive posts for help but needed a little bit more guidance on the modeling
of the glazing. I am using ECOTECT for the basic geometry and ECOTECT's
Radiance Panel to interface with Radiance.
I am modeling a white translucent glazing with about 50% transmittance
using the following parameters:
7 1 1 1 0 0 0.5 0.2
I would like to know if I am correct in my assumptions or if there is some
other way to model a translucent / frit glass (any resources on the web that
I can look up)
Additionally, I have not been able to figure how to show this trans
material inside the space in the final rendering in Radiance as it is
essentially invisible. I was reading up on the illum material type but could
not figure out how to apply it to this translucent glazing.
Any help on this will be appreciated.
Thanks.
Nikhil Kapur
CTG Energetics, Inc
9 4 9 . 4 2 8 . 6 2 7 1
