Hi Andy,
I think your roughness and absorption input labels are switched in this
widget.  This is a nice little tool - thanks!
Zack
On Fri, Apr 27, 2012 at 3:31 PM, Andy McNeil <[email protected]> wrote:
Hi Valeria,
Trans is a quick and easy way to model this type of glazing.
You can use this widget to generate a trans material definition by
entering your transmission and reflection parameters:
http://gaia.lbl.gov/people/andy/public/transwidget/However trans does not account for Fresnel effects that reduce
transmission of glass at non-normal incidence angles (
http://en.wikipedia.org/wiki/File:Amptitude_Ratios_air_to_glass.JPG\). So
treat trans results with some degree of caution.If you want to include fresnell effects and diffusion, you might consider
use a glass surface and a trans surface one in front of the other. Or you
could generate a BSDF and use the new BSDF material.Hope this helps,
AndyOn Apr 27, 2012, at 1:34 PM, Valeria De Giuli wrote:
> Dear all,
> I have to model a two-pane glass make up with a selective 6mm outer pane
with an integrated capillary slab (it is called kapilux), white tinted. The
obtained effect is a uniform and diffuse light transmittance. The only
technical data that I have are: 30% of direct visible transmittance and
15% of diffuse visible transmittance. I think I should model it with
"trans" material, but I don't know which parameters I have to use. Does
anybody has an idea?
> Thanks in advance. Best regards,
> Valeria
> Radiance-general mailing list
> [email protected]
> http://www.radiance-online.org/mailman/listinfo/radiance-general_______________________________________________
Zack Rogers, P.E., LEED AP BD+C
Daylighting Innovations, LLC
211 North Public Road, Suite 220
Lafayette, CO 80026
(303)946-2310
