Mkillum Question
Why is the visible light transmittance used with the glass primitive while the visible light transmission value is used in the illum primitive? See below example from chapter 1 pp 29 & 32 of RWR
For Pilkington Optifloat Clear 3mm glass the Visible Light Transmission is 89% (http://www.pilkington.com.au/resources/pilkingtonperformancedatasingleglazing.pdf)
The transmissivity is calculated using:
  icalc /usr/local/lib/ray/src/cal/cal/trans.cal
  Tn=0.89
  tn
  $1=0.969269687
Therefore for a glass definition you would use something like:
  mod glass window_glass
        3 0.97 0.97 0.97
But when you use mkillum (Rwr chapter 1, page 32 with alteration of the transmission value from 0.88 to 0.89 and transmittance from 0.96 to 0.97) the illum uses the visible light transmission value.
        3 0.97 0.97 0.97
  skyfunc brightfunc window_dist
  2 winxmit winxmit.cal
  window_dist illum window_illum
  1 window_glass
  3 0.89 0.89 0.89
  window_illum polygon window
  12 ...
Regards
Terry Mc Minn
Faculty of Built Environment, Art and Design Curtin University of Technology GPO Box U 1987 Perth 6845 Western Australia
Email: T.Mcminn@curtin.edu.au
CRICOS Provider Code: 00301J
Hi Terry,
The reason for the change is because the glass primitive takes into account internal reflections, which use the transmission value to compute transmittance as a function of angle. In contrast, the illum primitive doesn't account for these, which are reintroduced using the winxmit.cal pattern. This pattern is normalized to 100% transmittance, and must have normal transmittance as a multiplier on the material.
I don't know how to make it clearer than that -- I realize it's a bit confused, but it is correct.
Date: October 16, 2005 9:28:09 PM PDT
    Tn=0.89
    tn
    $1=0.969269687
        3 0.97 0.97 0.97
        3 0.97 0.97 0.97
    1 window_glass
    3 0.89 0.89 0.89
    12 ...
Regards
Terry Mc Minn
Hello Greg,
the material.
The missing link in the documentation! Quite clear!
Many thanks.
Regards
Terry Mc Minn
Western Australia
