I wonder if someone knows how to change Mkillum parameters.
It is said in the manual that parameters can be changged in the input file in
the form
#@mkillum variable=value option switch{+|-}..
I am not sure how I can use this input file and where I have to put it.
I really appreciate any comments.
Thanks!
mkillum takes a Radiance scene file on it's input, and that's where you have to put these sorts of options. The reason I did it that way is so you could change parameters between sections of your input files, instead of having them all fixed by the mkillum command line.
Date: November 5, 2004 11:14:17 AM PST
the form
Thanks!
An example:
Let's call the file illumvoid.rad : Its very first line is
#@mkillum c=d d=400 s=20
# creates around 1200*20 ray samples for an illum*.dat file, which samples the environment well
# first virtual emitter
void polygon t1
0 0 12
# second virtual emitter
void polygon t2
0 0 12
mkillum -ab 1 -ad 512 -as 256 -ar 5000 -av 14 14 14 octree_exterior < illumvoid.rad > illum1.rad
oconv all scene files illum1.rad > octree
rpict ... octree > picture
Dr. Moeck
Sent: Fri 11/5/2004 2:29 PM
Cc:
Subject: Re: [Radiance-general] mkillum parameter modify...
> From: "Woogie" <wxo110@psu.edu>
> file in
> the form
> Thanks!
