Thanks for the suggestion Greg; unfortunately that's not the case as the
script does not hang there and the just goes to the next line of the
batch file.
What's even funnier is that the same files run from another machine...
...which is what will happen for tonight and tomorrow I'll try to figure
out what's wrong with mine...
Still open to suggestions though!
Thanks
Giovanni
Sent: 23 January 2013 17:14
Subject: Re: [Radiance-general] misterious error
Hi Giovanni,
I suspect that your test.rad (or materials.rad) file has a line of the
form:
!some_script
that is hanging because it is attempting to read from the standard
input. Whatever script produced the ROPT= line is the one hanging up
oconv.
Date: January 23, 2013 8:23:36 AM PST
Dear List,
I'm hoping for some help as I'ma bit lost here.
I have a simple test scene with some light sources in it.
The scene is entirely described using radiance meshes (obj2mesh) and
the light sources are instead sent as polygons.
All the files are called In the *.rif file and then I simply run:
batch file.
Thanks
Giovanni
Hi Giovanni,
form:
!some_script
oconv.
Dear List,
Not sure that there is anything abnormal, I'm pasting here below my rif
file if that can give any insights,
I believe some settings in my machine have gone wrong... maybe \I just
need to reinstall radiance...
#start of rif file
scene= materials.rad test.rad
AMBFILE= test.amb
OCTREE= test.oct
RESOLUTION= 2382 1498
DETAIL= MEDIUM
VARIABILITY = MEDIUM
QUALITY= MEDIUM
the script does not hang there and the just goes to the next line of
the batch file.
figure out what's wrong with mine...
Thanks
Giovanni
Hi Giovanni,
form:
!some_script
oconv.
Dear List,
Not sure on this, as I do not remember if there are issues with spaces around the "=" sign. Your rif file has
all the other parameter names have the = sign right after the name, so what about
VARIABILITY= MEDIUM
Jack de Valpine
President
Visarc Incorporated
channeling technology for superior design and construction
#start of rif file
AMBFILE= test.amb
OCTREE= test.oct
DETAIL= MEDIUM
QUALITY= MEDIUM
Giovanni Betti
Sent: 23 January 2013 18:20
end lines in the rif file?
like DOS / UNIX?
G
the batch file.
Thanks
Giovanni
Hi Giovanni,
form:
!some_script
oconv.
Dear List,
In my own defense, rad should be robust to different line endings and spaces around variables, etc. I still think the problem is in the scene or material files. What happens when you run oconv on the command line, as opposed to doing it through rad? If it hangs, try redirecting input from an empty file just to be sure it isn't a stdin hang.
Date: January 23, 2013 11:58:14 AM PST
Hi Giovanni,
VARIABILITY= MEDIUM
Jack de Valpine
President
#start of rif file
AMBFILE= test.amb
OCTREE= test.oct
DETAIL= MEDIUM
QUALITY= MEDIUM
Giovanni Betti
like DOS / UNIX?
G
the batch file.
Thanks
Giovanni
Hi Giovanni,
form:
!some_script
oconv.
Dear List,
As a test reduce INDIRECT to 1, QUALITY to LOW, and the RESOLUTION to 230 x
150. Perhaps you are just not patient enough.
#start of rif file
AMBFILE= test.amb
OCTREE= test.oct
DETAIL= MEDIUM
QUALITY= MEDIUM
Giovanni Betti
like DOS / UNIX?
G
> the batch file.
> Thanks
> Giovanni
> From: Greg Ward [mailto:[email protected]]
> Hi Giovanni,
> form:
> !some_script
> oconv.
> -Greg
>> From: "Giovanni Betti" <[email protected]>
>> Dear List,
>> rad test.rif
>> the output in the console is:
>> oconv materials.rad test.rad > test.oct
>> set ROPT=-dp 512 -ar 31 -ms 0.49 -ds .3 -dt .1 -dc .5
> -dr 1 -ss 1
>> -st .1 -ab 2 - af test.amb -aa .15 -ad 800 -as 128 -av 10 10
>> 10 -lr 8 -lw 1e-4 -ad 2048 -as 1024 -dr 100 -lr 48 -av 0 0 0
>> and then nothing...
>> no errors, no warnings and (most importantly!) no image!
>> The computer does not even hang...
>> Can anybody offer an explanation?
>> Thanks a million in advance,
>> Giovanni
> Radiance-general mailing list
> [email protected]
> http://www.radiance-online.org/mailman/listinfo/radiance-general
> [email protected]
