I love when Greg shares these kung foo tips and deep insights to Radiance's underbelly, and then closes with "Does this make sense". Yes, it makes sense, after reading it like five times. Thanks, Greg, as always!
On Tue, Dec 1, 2015 at 9:51 AM, Greg Ward <[email protected] > <mailto:[email protected]>> wrote:
Hi Jan,
As you discovered, the code isn't sophisticated enough to handle
virtual source materials (mirror, prism, prism2) through the
mixfunc interface. (BTW, mixfunc also fails for light sources.) However, you can use the "alternate material" argument to the
mirror primitive to specify a different behavior for when the
mirror is not directly participating in the virtual source relay
calculation. You could have a chain like this, which would work:
void metal mat1
[arguments]
void plastic mat2
[arguments]
void mixfunc mat1+2
4 mat1 mat2 mixing_var mixit.cal
void mirror mmat1+2
1 mat1+2
3 .5 .5 .5
When the mirror material is participating in the virtual source
calculation, it reflects everything at 50%. When it's
participating in the interreflection calculation, or you look at
it directly, then it switches to the mixfunc mat1+2's behavior.
If one of your goals is to have the mixfunc control the amount of
reflected light in the virtual calculation, I'm afraid you will
need to use a brightfunc modifier on the mirror material,
instead. You can do this in conjunction with an alternate
material to make the behavior consistent if you like. In the
example above, let's say that mat1 is mirror-like with 80%
reflectance and mat2 is diffusing. You could use the same cal
file for your brightfunc, modifying the mirror primitive like so:
void brightfunc mir_amt
mir_amt mirror mmat1+2
1 mat1+2
3 .8 .8 .8
Does this make sense?
> From: Jan Wienold <[email protected] <mailto:[email protected]>>
> Subject: [Radiance-general] mirror and mixfunc
> Date: December 1, 2015 6:44:00 AM PST
> Hi all,
> I got stuck a bit applying mixfunc and mirror material. It seems
that the check for secondary light sources is partly disabled when
applying (at least I assume so).
> A simple example:
> lets assume an ideal mirror
> void mirror testmat1
> 0
> 3 1 1 1
> If I use just this material on a surface and start an rtrace
sending to the surface, then I get the correct result for both
options - either rtrace or rtrace -I. So far so good.
> In case I use a (stupid, but simple) mixfunc:
> void mixfunc test_mix
> 4 testmat1 testmat1 0.5 .
> 0
> I should get the same result, since I'm mixing the same material
with a fixed value.
> But: rtrace -I delivers only 0, whereas rtrace delivers the
correct value. So it seems that mixfunc cannot be applied with
mirror, when the -I option is used. Or I did something wrong?
> I used -dr 2 and -dt 0 in both cases.
> Of course my ultimate goal is not mixing that simple but mixing
two different material types, also depending on the angle of
incidence, but this simple example shows the principle problem.
> Is there any solution using mixfunc and mirror when using rtrace
-I ?
> Jan
