mgf2inv VRML export
Hi Greg, hi list,
from time to time I am using mgf2inv with the "-vrml" option to export and
view my models.
This time I wanted to do the conversion with rad2mgf and mgf2inv -vrml on
Windows using the
NREL binaries. However, the resulting files are corrupt due to bad number
representations and
normal descriptions.
For example the description of a face in the VRML-file created with the
Linux binaries is:*
DEF ceil_fac_001 Group {
  Separator {
    USE ceil_mat
    Coordinate3 {
      point [ -2.000000000e+00 +4.500000000e+00 +2.162119874e+00,
              -1.500000000e+00 +4.500000000e+00 +3.000000000e+00,
              -1.500000000e+00 +5.000000000e+00 +1.461123454e+00,
              -2.000000000e+00 +5.000000000e+00 +6.232433278e-01 ]
    IndexedFaceSet {
      coordIndex [ 0, 1, 2, 3 ]
In the files created with the Windows version the same face is described as:
  Separator {
    USE ceil_mat
    Coordinate3 {
      point [ -2.000000000e+000 +4.500000000e+000 +2.162119874e+,
              -1.500000000e+000 +4.500000000e+000 +3.000000000e+,
              -1.500000000e+000 +5.000000000e+000 +1.461123454e+,
              -2.000000000e+000 +5.000000000e+000 +6.232433278e- ]
    Normal {
      vector [ 00
+0.000 +0.000 +0.0-1.500000000e+000 +4.500000000e+000 +3.000000000e+,
               00
+0.000 +0.000 +0.0-1.500000000e+000 +5.000000000e+000 +1.461123454e+,
               00
+0.000 +0.000 +0.0-2.000000000e+000 +5.000000000e+000 +6.232433278e-,
               01
+0.000 +0.000 +0.000 ]
    IndexedFaceSet {
      normalIndex [ 0, 1, 2, 3 ]
*Obviously, two things are corrupt:
- the z-coordinates are missing their exponents
- the normal vector coordinates are messed up
Moreover, for me it's unclear why normal vectors are written (needed ??) in
the Windows version, while
they are completely missing in the Linux version.
I believe that all this has something to do with de definition of VERTFMT
in src/cv/mgf2inv.c
*#define VERTFMT "%+16.9e %+16.9e %+16.9e\n%+6.3f %+6.3f %+6.3f"*
Any ideas how to solve that for both platforms??
David
Hi David,
AFAIK, the sources for those two programs were not touched in the Windows binary project. I don't fully understand the behavior of this program right now. I will check with Kitware to see if any changes were in fact made to that source in order to get it to work on Windows.
Golden, CO 80401
303.275.4319
On 4/30/12 6:35 AM, "David Geisler-Moroder" <[email protected]<mailto:[email protected]>> wrote:
Hi Greg, hi list,
from time to time I am using mgf2inv with the "-vrml" option to export and view my models.
This time I wanted to do the conversion with rad2mgf and mgf2inv -vrml on Windows using the
NREL binaries. However, the resulting files are corrupt due to bad number representations and
For example the description of a face in the VRML-file created with the Linux binaries is:
  Separator {
    USE ceil_mat
    Coordinate3 {
    IndexedFaceSet {
  Separator {
    USE ceil_mat
    Coordinate3 {
    Normal {
      vector [ 00
               00
               00
               01
    IndexedFaceSet {
Moreover, for me it's unclear why normal vectors are written (needed ??) in the Windows version, while
I believe that all this has something to do with de definition of VERTFMT in src/cv/mgf2inv.c
David
Hi David,
I found the problem, and can figure out how to fix it. The code assumes that exponents have two digits only, which is still true on most Unix machines. I guess they're making room for "long double's" (128-bit IEEE float) and don't have different code for that than the "regular" doubles.
I will check in a fix later today -- thanks so much for spotting this.
Date: April 30, 2012 8:41:17 AM PDT
Hi David,
Hi Greg, hi list,
Separator {
   USE ceil_mat
   Coordinate3 {
   IndexedFaceSet {
Separator {
   USE ceil_mat
   Coordinate3 {
   Normal {
     vector [ 00
              00
              00
              01
   IndexedFaceSet {
#define VERTFMT "\+16\.9e +16.9e \+16\.9e\\n+6.3f \+6\.3f +6.3f"
David
Hi Greg, Rob,
thanks a lot for the quick responses and for the fix!
However, I need to wait for the new NREL-binaries to use the fixed version
(or maybe finally step into the CMake thing to get the Windows bins
compiled by myself... :wink: ).
David
2012/4/30 Gregory J. Ward <[email protected]>
Hi David,
> From: "Guglielmetti, Robert" <[email protected]>
> Hi David,
> On 4/30/12 6:35 AM, "David Geisler-Moroder" <[email protected] > <mailto:[email protected]>> wrote:
> Hi Greg, hi list,
and view my models.
Linux binaries is:
> Separator {
> USE ceil_mat
> Coordinate3 {
> IndexedFaceSet {
as:
> Separator {
> USE ceil_mat
> Coordinate3 {
> Normal {
> vector [ 00
> 00
> 00
> 01
> IndexedFaceSet {
> Cheers,
> David
Radiance-dev mailing list
DI Dr. David Geisler-Moroder
Hofwaldweg 14/20
6020 Innsbruck
Hi David,
I am trying to sort out two other issues with the Windows binaries, but I can push out a new Windows installer tomorrow morning for you with this fix. We can talk offline if you want to talk about getting up and running with CMake, too.
Golden, CO 80401
303.275.4319
Hi Greg, Rob,
However, I need to wait for the new NREL-binaries to use the fixed version (or maybe finally step into the CMake thing to get the Windows bins compiled by myself... :wink: ).
David
2012/4/30 Gregory J. Ward <[email protected]<mailto:[email protected]>>
Hi David,
On 4/30/12 2:11 PM, "David Geisler-Moroder" <[email protected]<mailto:[email protected]>> wrote:
From: "Guglielmetti, Robert" <[email protected]<mailto:[email protected]>>
Hi David,
On 4/30/12 6:35 AM, "David Geisler-Moroder" <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
Hi Greg, hi list,
Separator {
   USE ceil_mat
   Coordinate3 {
   IndexedFaceSet {
Separator {
   USE ceil_mat
   Coordinate3 {
   Normal {
     vector [ 00
              00
              00
              01
   IndexedFaceSet {
David
Hofwaldweg 14/20
6020 Innsbruck
Does this mean the Radiance CMake environment is available for general consumption?
Palbinder Sandher
Software Platform Engineer
T:+44 (0) 141 945 8500
F:+44 (0) 141 945 8501
**Design, Simulate + Innovate with the <Virtual Environment>**
Integrated Environmental Solutions Limited. Registered in Scotland No. SC151456
Registered Office - Helix Building, West Of Scotland Science Park, Glasgow G20 0SP
Email Disclaimer
Sent: 30 April 2012 22:28
To: code development
Subject: Re: [Radiance-dev] mgf2inv VRML export
Hi David,
Golden, CO 80401
303.275.4319
Hi Greg, Rob,
David
Hi David,
Hi David,
Hi Greg, hi list,
Separator {
   USE ceil_mat
   Coordinate3 {
   IndexedFaceSet {
Separator {
   USE ceil_mat
   Coordinate3 {
   Normal {
     vector [ 00
              00
              00
              01
   IndexedFaceSet {
David
Hofwaldweg 14/20
6020 Innsbruck
It does indeed, Pally. I just announced I on radiance-general, and was
planning an update on how to use the Cmake system on your own system, to
be posted to tis dev list. In the meantime, you can check out what we have
on offer at:
https://openstudio.nrel.gov/getting-started-developer/getting-started-radia
nce
There are still a couple of issues (typically Windows issues) cropping up
(like the one David discovered recently) that Greg is actively fixing and
pushing into HEAD, but we are currently updating the HEAD installers every
two weeks. So, for the latest-greatest Radiance, you'll want to get up to
speed with Cmake.
consumption?
Excellent Rob, I'm a bit busy with an impending software release right now but I'll definitely have a go later this month.
Thanks for all the hard work (and I really should get on the radiance-general list as I seem to miss a lot of announcements only being on here).
Palbinder Sandher
T: +44 (0) 141 945 8500
F: +44 (0) 141 945 8501
Email Disclaimer
Sent: 01 May 2012 17:43
consumption?
on offer at:
nce
speed with Cmake.
My pleasure Pally (actually it was (is) a giant PITA, and Greg Ward, Axel
Jacobs and the Kitware guys deserve a lot of the credit for making this a
success)!
And yeah, -general and -dev are a package deal, you need to monitor both
lists to get the full monty.
Golden, CO 80401
303.275.4319
on here).
Palbinder Sandher
http://www.iesve.com
SC151456
Glasgow G20 0SP
Email Disclaimer
consumption?
on offer at:
OpenStudio
a
nce
speed with Cmake.
I'm sure it's appreciated though Rob =)
Certainly for anyone like myself who has to build Radiance on Windows as trying to use the old Scons system was also a massive PITA but at least this is something which can be maintained and is cross platform.
Signing myself up to Radiance-general now :wink:
Again thanks to everyone involved for all the time, effort, blood, sweat, tears & anything else required to get this up & running.
Palbinder Sandher
Email Disclaimer
Sent: 01 May 2012 18:04
success)!
Golden, CO 80401
303.275.4319
on here).
Palbinder Sandher
SC151456
Glasgow G20 0SP
Email Disclaimer
consumption?
on offer at:
OpenStudio
a
nce
speed with Cmake.
the last mgf2inv update fixed the problem with the tree digit exponents.
However, on Windows (thanks again Rob for providing the new binaries!)
the normals are still messed up -- see below.
The strange thing is that using the Windows binaries normals are printed
whereas in Linux the normals are not printed at all.
The output in Windows is:
*DEF ceil_fac_001 Group {
  Separator {
    USE ceil_mat
    Coordinate3 {
      point [ -2.000000000e+000 +4.500000000e+000 +2.853170182e+000,
              -1.500000000e+000 +4.500000000e+000 +3.000000000e+000,
              -1.500000000e+000 +5.000000000e+000 +2.544315366e+000,
              -2.000000000e+000 +5.000000000e+000 +2.397485548e+000 ]
    Normal {
      vector [ +0.000 +0.000 +0.0-1.500000000e+000 +4.500000000e+000
+3.000000000e+000,
+2.544315366e+000,
+2.397485548e+000,
    IndexedFaceSet {
It seems the vlist[] is corrupt under Win because in line 546 of mgf2inv.c
the strcmp is
nonzero. To me it seems that from the the second vertex on the vertices are
written 3 bytes
left of where they should be -- these could be just the bytes that Win (or
any system with
3 digit exponents) needs more?!
All in all it's probaly the VFLEN that is correct for a 2 digit exponent
(72 = VSEPPOS (50) +
space (1) + len(VZVECT) (20) + len(\0) (1)) but not for a 3 digit exponent.
David
