Hi Lars,
You should check that you don't have a limit placed on your data size if you are getting out-of-memory errors. Run the command in csh or tcsh:
% limit
It should give you a list of resource limits currently in effect. If the datasize says anything besides "unlimited", you should run the command "unlimit datasize" before running Radiance. Better still, but such a command in your .cshrc or .tcshrc file in your home directory. If you are still getting out-of-memory errors after that, there is either a problem with your virtual memory size or a problem with Radiance.
Raphael wrote to tell me that ximage does a segmentation fault when you re-expose the image in his version of Linux. I found the problem -- a pointer was being freed twice due to a library call that either changed or always freed twice and no one noticed before. Anyway, I've fixed the problem and will quietly put it into this release rather than creating a patch, so you might want to download it again or patch it yourself if you have a slow connection with the following code change:
ray/src/px/x11image.c (line 781):
free(ourdata);
change to:
/* free(ourdata); This is done in XDestroyImage()! */
Then simply run "rmake install" in that directory, presuming you've run "makeall install" previously. Running "makeall install" again also works.
Regarding pcond and macbethcal, I don't know what the problem is, but I don't recommend this method anymore, anyway. Macbathcal works very well on calibrating input paths, but less well on calibrating output paths. Unfortunately, I don't have a really good solution to offer for this at the moment....
