Meaning of EPW file's minute field and why is it 60 in TMY2-based EPW and 0 in TMY3-based EPW?
Hello everyone,
I am new to EnergyPlus, Daysim and Radiance. I am looking at the process of
converting EPW files to WEA files.
I am trying to understand the meaning of the minute field in an EPW file.
I read in
http://www.radiance-online.org/pipermail/radiance-general/2012-October/008968.html
that the minutes field does not relate to '*the time when the measurement
was recorded, but to the **recording interval'.*
The EPW Data Dictionary (
http://bigladdersoftware.com/epx/docs/8-3/auxiliary-programs/energyplus-weather-file-epw-data-dictionary.html#field-minute)
is not useful for understanding the meaning of the minutes field, as it
simply says:
* Field: Hour - This is the hour of the data. (1 - 24). Hour 1 is 00:01 to
01:00. Cannot be missing.
* Field: Minute - This is the minute field. (1..60)
If I take the EPW file for Gatwick Airport in London (
https://energyplus.net/weather-location/europe_wmo_region_6/GBR//GBR_London.Gatwick.037760_IWEC)
I see that its minute fields are set to 60 (hours and minutes in bold):
DATA PERIODS,1,1,Data,Sunday, 1/ 1,12/31
1991,1,1,*1,60*,...
1991,1,1,*2,60*,...
If instead I take the TMY3-based EPW file for Central Park in New York (
https://energyplus.net/weather-location/north_and_central_america_wmo_region_4/USA/NY/USA_NY_New.York-Central.Park.725033_TMY3),
I see that its minute fields are set to 0 :
1976,1,1,*1,0*,...
1976,1,1,*2,0*,...
Yet if I take the TMY2-based EPW file for Central Park in New York (
https://energyplus.net/weather-location/north_and_central_america_wmo_region_4/USA/NY/USA_NY_New.York.City-Central.Park.744860_TMY2),
I see that its minute fields are set to 0:
1976,1,1,*1,60*,...
1976,1,1,*2,60*,...
Can someone please explain in simple terms what the meaning is of the
minutes field?
Why is there a difference in the value of the minutes fields in the
IWEC-based EPW file for Gatwick (value is 0) and in the TMY3-based EPW file
for Central Park (value is 60)? What is the minutes field telling me about
the data?
Why is there a difference in the value of the minutes fields in the EPW
file for Central Park depending on whether it is TMY2-based (in which case
the value is 60) or TMY3 based (in which case the value is 0)?
Thank you in advance for your help,
Philip Schwarz
If you take a look at the tmy2 man page, you'll see that illuminance is for
the 60 minutes preceding the time. Thus, the values for a time of "10:60"
maps to the hour starting 10:00:00 and ending at 10:59:59.
Field Position
Element
[image: page26image4992] [image: page26image5312]
Values
[image: page26image6240] [image: page26image6560] [image: page26image7032]
Definition
[image: page26image8224]
030 - 035
030 - 033 034
035
Diffuse Horizontal Radiation Data Value
Flag for Data Source
Flag for Data Uncertainty
0 - 700 A - H, ?
0-9
[image: page26image14200] [image: page26image14520]
Amount of solar radiation in Wh/m2 received from the sky (excluding the
solar disk) on a horizontal surface* during the 60 minutes preceding the
hour indicated *
[image: page26image17168]
036 - 041
036 - 039 040
041
Global Horiz. Illuminance Data Value
0 - 1300 I, ?
0-9
Average total amount of direct and diffuse illuminance in hundreds of lux
received on a horizontal surface *during the 60 minutes preceding the hour
indicated.*
0 to 1300 = 0 to 130,000 lux
042 - 047
042 - 045 046
047
Direct Normal Illuminance Data Value
[image: page26image28000] [image: page26image28320]
0 - 1100 I, ?
0-9
[image: page26image30064]
Average amount of direct normal illuminance in hundreds of lux received
within a 5.7 degree field of view centered on the sun *during the 60
minutes preceding the hour indicated*. 0 to 1100 = 0 to 110,000 lux
048 - 053
048 - 051 052
053
Diffuse Horiz. Illuminance Data Value
[image: page26image36608] [image: page26image36928]
0 - 800 I, ?
0-9
[image: page26image38672]
Average amount of illuminance in hundreds of lux received from the sky
(excluding the solar disk) on a horizontal surface *during the 60 minutes
preceding the hour indicated.*
0 to 800 = 0 to 80,000 lux
From: http://rredc.nrel.gov/solar/pubs/tmy2/pdfs/tmy2man.pdf
On Tue, Apr 4, 2017 at 3:06 AM, Philip Schwarz < [email protected]> wrote:
Hello everyone,
of converting EPW files to WEA files.
I read in http://www.radiance-online.org/pipermail/radiance-
general/2012-October/008968.html that the minutes field does not relate
to '*the time when the measurement was recorded, but to the **recording
interval'.*
The EPW Data Dictionary (http://bigladdersoftware.com/epx/
data-dictionary.html#field-minute) is not useful for understanding the
meaning of the minutes field, as it simply says:
to 01:00. Cannot be missing.
region_6/GBR//GBR_London.Gatwick.037760_IWEC) I see that its minute
1991,1,1,*1,60*,...
1991,1,1,*2,60*,...
Central.Park.725033_TMY3), I see that its minute fields are set to 0 :
1976,1,1,*1,0*,...
1976,1,1,*2,0*,...
Central.Park.744860_TMY2), I see that its minute fields are set to 0:
1976,1,1,*1,60*,...
1976,1,1,*2,60*,...
minutes field?
the data?
Philip Schwarz
Sorry, that sent before I was ready. Similar verbiage is found for TMY3 on
http://www.nrel.gov/docs/fy08osti/43156.pdf\. My best guess for why there is
a zero in the minutes for Gatwick in the TMY3 and a 60 in the TMY2 is that
someone made a mistake. But I'm sure a more precise answer will emerge on
this list.
Table 1-3. TMY3 data fields (lines 3-8762)
Field
Element
Unit or Range
Resolution
[image: page11image5464]
Description
1
Date
MM/DD/YYYY
Date of data record
2
Time
HH:MM
Time of data record (local standard time)
3
Hourly extraterrestrial radiation on a horizontal surface
Watt-hour per square meter
1 Wh/m2
Amount of solar radiation received on a horizontal surface at the top of
the atmosphere during the 60-minute period ending at the timestamp
4
Hourly extraterrestrial radiation normal to the sun
1 Wh/m2
Amount of solar radiation received on a surface normal to the sun at the
top of the atmosphere during the 60- minute period ending at the timestamp
5
Global horizontal irradiance
1 Wh/m2
Total amount of direct and diffuse solar radiation received on a horizontal
surface during the 60-minute period ending at the timestamp
for the 60 minutes preceding the time. Thus, the values for a time of
"10:60" maps to the hour starting 10:00:00 and ending at 10:59:59.
Field Position
Element
Values
Definition
030 - 035
030 - 033 034
035
0 - 700 A - H, ?
0-9
hour indicated *
036 - 041
036 - 039 040
041
0 - 1300 I, ?
0-9
hour indicated.*
042 - 047
042 - 045 046
047
0 - 1100 I, ?
0-9
048 - 053
048 - 051 052
053
0 - 800 I, ?
0-9
On Tue, Apr 4, 2017 at 3:06 AM, Philip Schwarz <philip.johann.schwarz@ > googlemail.com> wrote:
Hello everyone,
I read in http://www.radiance-online.org/pipermail/radiance-general
/2012-October/008968.html that the minutes field does not relate to '*the
interval'.*
The EPW Data Dictionary (http://bigladdersoftware.com/epx/docs/8-3/
6/GBR//GBR_London.Gatwick.037760_IWEC) I see that its minute fields are
1991,1,1,*1,60*,...
1991,1,1,*2,60*,...
america_wmo_region_4/USA/NY/USA_NY_New.York-Central.Park.725033_TMY3), I
1976,1,1,*1,0*,...
1976,1,1,*2,0*,...
1976,1,1,*1,60*,...
1976,1,1,*2,60*,...
minutes field?
the data?
Philip Schwarz
A bit more info...
The minute field in the EPW has little meaning (ever) for hourly based
files. Frankly the TMY2 should have been 00 rather than 60. They have some
meaning for subhourly files but aren't ever parsed for EnergyPlus usage.
Note that the TMY3 files on EnergyPlus.net are not updated to the latest
version (TMY3a) from January 2015 (correcting illuminance, precipitation
and a few other issues).
Up to date TMY3a data are available from http://climate.onebuilding.org .
The zips there also include .WEA (Daysim format) as well as EPW, CLM (ESP-r
format) along with substantially expanded statistics. Climate.OneBuilding
has more than 2,200 locations throughout the world -- many not available on
EnergyPlus.net.
is a zero in the minutes for Gatwick in the TMY3 and a 60 in the TMY2 is
that someone made a mistake. But I'm sure a more precise answer will emerge
on this list.
Field
Element
Unit or Range
Resolution
Description
1
Date
MM/DD/YYYY
Date of data record
2
Time
HH:MM
3
1 Wh/m2
4
1 Wh/m2
5
1 Wh/m2
horizontal surface during the 60-minute period ending at the timestamp
Field Position
Element
Values
page26image7032]
Definition
030 - 035
030 - 033 034
035
0 - 700 A - H, ?
0-9
hour indicated *
036 - 041
036 - 039 040
041
0 - 1300 I, ?
0-9
hour indicated.*
042 - 047
042 - 045 046
047
0 - 1100 I, ?
0-9
048 - 053
048 - 051 052
053
0 - 800 I, ?
0-9
minutes preceding the hour indicated.*
On Tue, Apr 4, 2017 at 3:06 AM, Philip Schwarz < >> [email protected]> wrote:
Hello everyone,
interval'.*
r-file-epw-data-dictionary.html#field-minute) is not useful for
understanding the meaning of the minutes field, as it simply says:
1991,1,1,*1,60*,...
1991,1,1,*2,60*,...
1976,1,1,*1,0*,...
1976,1,1,*2,0*,...
1976,1,1,*1,60*,...
1976,1,1,*2,60*,...
minutes field?
the data?
Philip Schwarz
