Has anyone got this going?
(Yes! I have managed to get it built and installed. No, I have no idea if it is actually working. More, later, when I've tested the thing.)
Randolph
Randolph
Randolph M. Fritz <randolph+LD@...> writes:
I am pleased to be able to say that I have been able to get the simulation,
though not the timing part, of this benchmark running. There is no "time"
command in the native Windows environment, and I don't yet know how to use
similar commands in the Windows Power Shell. Looking hopeful, though of
course I have not yet seen the output.
Mark Stock, if you're reading, would you like my cross-platform changes to
the .rad files? Windows, of course, does not have a "cat" command, which
means that "!cat" has to be replaced with "!xform".
Randolph
Side note on the use of "!cat" I often see things like this:
!cat input1.rad input2.rad | xform -ry 20
Which is completely silly. Why not just use:
!xform -ry 20 input1.rad input2.rad
Even if you are going to a program that expects input on stdin, you can redirect it instead:
!fussy_program < input | second_program etc...
I've seen almost no one use cat for a reason in a Radiance file. (No offense Mark, as I haven't even looked at yours!)
Date: June 27, 2013 5:04:11 PM PDTRandolph M. Fritz <randolph+LD@...> writes:
if it is actually working. More, later, when I've tested the thing.)I am pleased to be able to say that I have been able to get the simulation,
course I have not yet seen the output.Mark Stock, if you're reading, would you like my cross-platform changes to
means that "!cat" has to be replaced with "!xform".Randolph
I am pleased to be able to say that, in fact, I ran a successful simulation.
My hasty hack compilations of libtiff 3.9.7 (the last version 3 libtiff)
and zlib 1.2.8 also worked, which was nice to see.
Performance, well, not so good. It took 4219.9 wall clock seconds on a
fairly capable Xeon, which is 1.5-2x slower than I expect based on the
benchmark table. I suspect some tweaking of compilation options would
considerably improve the performance, even with the relatively blah
Microsoft VC10 compiler.
Randolph
Greg, Randolph,
I admit that my use of "cat" is simply habit---I saw it once (probably over 15 years ago) and never let go of it. I am actually not as savvy with Unix as I am on TV.
By all means make the benchmark as portable as you can and send me the changes. I will incorporate them as soon as I can.
Mark
-GregFrom: "Randolph M. Fritz" <[email protected]>
Radiance-dev mailing list
I am silly. This vestigial code is still in OpenStudio, for "Radiance Classic" calcs with a continuous sky:
catCommand = "cat"
if /mswin/.match(RUBY_PLATFORM) or /mingw/.match(RUBY_PLATFORM)
catCommand = "type"
end
system("#{catCommand} ./numeric/#{space_name}.map | rtrace #{rtrace_args} …")
In this case, this really seemed to be the most direct way in. In any event, !type would be the true one-for-one replacement for !cat when porting Mark's scene to windoze.
Mark,
I've seen lots of people use it, probably because it fits what people expect to see in an inline command more than the stdin redirection. I think there are even some examples in "Rendering with Radiance" using it, so you're in good company...
Date: June 28, 2013 7:58:43 AM PDTGreg, Randolph,
Mark
http://www.radiance-online.org/mailman/listinfo/radiance-dev_______________________________________________
I favor "xform" with no options for this job; if the system has Radiance, I
expect it will have "xform", regardless of what other commands are or are
not available. But, YMMV.
Randolph
Rob Guglielmetti <rob.guglielmetti@...> writes:
catCommand = "cat"
catCommand = "type"
endsystem("#{catCommand} ./numeric/#{space_name}.map | rtrace #{rtrace_args} …")
boy, was that last remark off-target.
I don't understand how that code can work? Does something in that
implementation of "system" convert slashes to backslashes?
Anyhow, in this case, could one just perhaps divert rtrace's input?
system("rtrace #{rtrace_args} < ./numeric/#{space_name}.map")
Or would that fail?
Redirecting the input works better on both Windows and Unix than cat, to my earlier point.
Sent from my iPad
catCommand = "cat"
catCommand = "type"
implementation of "system" convert slashes to backslashes?Anyhow, in this case, could one just perhaps divert rtrace's input?
Or would that fail?
I have benchmarked Relux with the Radiance (or 'Raytracer', as they call it now) engine under Windows. This was done with Process Monitor, which is free download from the M$ site:
It's not quite the same as the UNIX 'time' command, but saves you sitting there with the old stop watch.
What you do is you launch PM and set up a filter for 'rpict', and/or anything else you wish to benchmark. Now run the benchmark. PM will capture the start and end time of this process. You can export the result to a text file. You still need to work out the runtime:
runtime = end - start.
It's not terribly elegant, but does work.
PM tends to be a little temperamental. I never got it to work on certain machines. It also might crash unexpectedly.
Cheers
Axel
Measure-Command in PowerShell would be a much better solution -> http://technet.microsoft.com/en-us/library/ee176899.aspx
I was planning on making the necessary tweaks to Mark's benchmarks so they run on Windows via PowerShell but alas I never have any time for anything interesting.
Palbinder Sandher
Software Platform Engineer
T: +44 (0) 141 945 8500
F: +44 (0) 141 945 8501
http://www.iesve.com
**Design, Simulate + Innovate with the <Virtual Environment>**
Integrated Environmental Solutions Limited. Registered in Scotland No. SC151456
Registered Office - Helix Building, West Of Scotland Science Park, Glasgow G20 0SP
Email Disclaimer
Sent: 29 June 2013 16:48
To: [email protected]
Subject: Re: [Radiance-dev] Mark Stock's benchmark on native Windows Radiance
Cheers
Axel
