Managing Radiance X Windows on Windows (WSL2 + VcXsrv)
Many Radiance tools (rview, ximage, objview, etc.) open X11
windows.
Under Windows + WSL2, those windows can:
- Open oversized\
- Appear off-screen\
- Ignore geometry hints\
- Behave inconsistently with multi-monitor or RDP
Here is a stable setup and a simple solution.
Disable WSLg (Use Pure X11)
On Windows 11, WSLg (Wayland/Weston) is enabled by default.
For deterministic X11 behavior, disable it.
Create:
C:\Users\<username>\.wslconfig
Contents:
[wsl2]
guiApplications=false
Then in PowerShell:
wsl --shutdown
Install and Launch VcXsrv
Install VcXsrv.
Launch it with:
vcxsrv.exe :0 -multiwindow -clipboard -wgl -ac
Important flag:
-ac
This disables access control so WSL clients can connect.
Inside WSL (~/.bashrc):
export DISPLAY=$(grep nameserver /etc/resolv.conf | awk '{print $2}'):0.0
Test:
xclock
The Window Placement Problem
Radiance tools such as:
rviewximageobjview
often open at inconvenient sizes or positions.
rview -geometry is unreliable under Windows window management.
Rather than fighting the X window manager, control placement from
Windows.
Practical Solution: AutoHotkey Hotkey Snap
Install AutoHotkey (v2).
Create a script like:
#Requires AutoHotkey v2.0
#SingleInstance Force
; Ctrl+Alt+M → snap active window to lower-right quarter
^!m:: {
MonitorGetWorkArea(1, &L, &T, &R, &B)
monW := R - L
monH := B - T
x := Floor(monW/2)
y := Floor(monH/2)
w := Floor(monW/2)
h := Floor(monH/2)
WinRestore("A")
WinMove(x, y, w, h, "A")
Run the script. Then:
- Open
rview,ximage, orobjview - Press Ctrl+Alt+M
- The window snaps to the lower-right quadrant
This works regardless of:
- Screen resolution
- RDP vs local console
- Multi-monitor setups
It avoids continuous auto-snapping and lets users move windows freely
afterward.
Summary
For Radiance on Windows via WSL2:
- Disable WSLg\
- Use VcXsrv with
-ac\ - Set
DISPLAYproperly\ - Use AutoHotkey for window control
This provides a stable and predictable X11 workflow for Radiance users.
**XWin_LowerRightQuarter.ahk**
^!m:: {
; Get primary monitor work area (excludes taskbar)
monW := R - L
monH := B - T
x := Floor(monW/2)
y := Floor(monH/2)
w := Floor(monW/2)
h := Floor(monH/2)
WinRestore("A")
; Optional: Ctrl+Alt+F → full screen (monitor work area)
^!f:: {
WinRestore("A")
WinMove(L, T, R-L, B-T, "A")
; Optional: Ctrl+Alt+C → center window at 1200x800
^!c:: {
monW := R - L
monH := B - T
w := 1200
h := 800
x := L + Floor((monW - w)/2)
y := T + Floor((monH - h)/2)
WinRestore("A")
