Dear List,
has someone experience with radiance and new MacOS 10.10? I tried it and got some unpleasant results: If you start rad with the -N option (for example: rad -N 4 -o x11 -v hem test.rif) it start as usual, but after a few seconds it seems to stuck, i. e. not responding to input, no further refining, no processor load. The processes seem to be waiting for something (forever):
1447 s000 S+ 0:00.00 rad -N 4 -o x11 -v hem test.rif
1450 s000 S+ 0:00.03 rvu -vth -vp 0 0 0.001 -vd 0 0 1 -vu 0 1 0 -vh 180 -vv 180 -vo 0 -va 0 -vs 0 -vl 0 -dp 512 -
1452 s000 S+ 0:00.25 rvu -vth -vp 0 0 0.001 -vd 0 0 1 -vu 0 1 0 -vh 180 -vv 180 -vo 0 -va 0 -vs 0 -vl 0 -dp 512 -
1453 s000 S+ 0:00.24 rvu -vth -vp 0 0 0.001 -vd 0 0 1 -vu 0 1 0 -vh 180 -vv 180 -vo 0 -va 0 -vs 0 -vl 0 -dp 512 -
1454 s000 S+ 0:00.24 rvu -vth -vp 0 0 0.001 -vd 0 0 1 -vu 0 1 0 -vh 180 -vv 180 -vo 0 -va 0 -vs 0 -vl 0 -dp 512 -
1455 s000 S+ 0:00.28 rvu -vth -vp 0 0 0.001 -vd 0 0 1 -vu 0 1 0 -vh 180 -vv 180 -vo 0 -va 0 -vs 0 -vl 0 -dp 512 -
Similar things happen if you use it without -o x11 (rad -N 4 -v hem test.rif): some process start, parts of the image will be rendered. Than the load goes to zero and nothing happens any more. Here you can see some zombies:
1315 s000 S+ 0:00.01 rad -N 4 -v hem test.rif
1318 s000 Z+ 0:00.00 (rad)
1325 s000 S+ 0:00.00 rpict -S 1 -PP pfM4wGSj -dp 512 -ar 32 -ms 0.05 -ds .3 -dt .1 -dc .5 -dr 1 -ss 1 -st .1 -ab
1408 s000 S+ 0:00.00 rad -N 4 -v hem test.rif
1409 s000 S+ 0:00.01 rpiece -F test_hem_rpsync.txt -PP pfM4wGSj -vth -vp 0 0 0.001 -vd 0 0 1 -vu 0 1 0 -vh 180 -v
1410 s000 S+ 0:00.00 rpict -S 1 -PP pfM4wGSj -dp 512 -ar 32 -ms 0.05 -ds .3 -dt .1 -dc .5 -dr 1 -ss 1 -st .1 -ab
1411 s000 Z+ 0:00.00 (rpict)
1412 s000 S+ 0:00.00 rad -N 4 -v hem test.rif
1413 s000 S+ 0:00.01 rpiece -F test_hem_rpsync.txt -PP pfM4wGSj -vth -vp 0 0 0.001 -vd 0 0 1 -vu 0 1 0 -vh 180 -v
1414 s000 S+ 0:00.00 rpict -S 1 -PP pfM4wGSj -dp 512 -ar 32 -ms 0.05 -ds .3 -dt .1 -dc .5 -dr 1 -ss 1 -st .1 -ab
1416 s000 S+ 0:00.01 rpiece -F test_hem_rpsync.txt -PP pfM4wGSj -vth -vp 0 0 0.001 -vd 0 0 1 -vu 0 1 0 -vh 180 -v
1417 s000 S+ 0:00.00 rpict -S 1 -PP pfM4wGSj -dp 512 -ar 32 -ms 0.05 -ds .3 -dt .1 -dc .5 -dr 1 -ss 1 -st .1 -ab
There is nothing in the logs. I got the same results with the precompiled binaries and binaries compiled from the head revision under 10.10 with Xcode 6.1.
Any suggestions?
Andreas Noback
HI Andreas,
I am sorry to hear about this issue, and it is unlikely that there is any way to debug it. A hung process doesn't respond to debugging, either!
The best approach is to kill one of the processes using "kill -QUIT" and seeing if it leaves behind a diagnostic file in $HOME/Library/Logs/CrashReporter/. Then at least, we may find out what routine it is hanging in.
The only other idea I had is to disable "App Nap" system-wide to see if this is causing the problem. See:
10.9: Disable App Nap in OS X - defaults-write.com
I don't know why this would affect non-application processes, or why it would present an issue in 10.10 if it wasn't an issue in 10.9, but it's worth a try.
I will see if I can reproduce this on my copy of Yosemite as well.
Subject: [Radiance-dev] MacOS Yosemite
Date: November 18, 2014 1:25:27 AM PST
Dear List,
Any suggestions?
Andreas Noback
Hi Andreas,
A quick follow-up to this. I tried it out on my copy of Yosemite, and confirmed the problem. It seems to be an intermittent problem with the system select() call, which means there's little I can do about it except hope Apple recognizes the issue and posts a patch at some point. The last change I made in this code related to a hanging condition was in 1997, and it's been working across Unix implementations since then.
For now, I can only suggest you avoid multiprocessing until the next patch release. You can try reporting a bug to Apple, but without a simple test case to reproduce it, they are unlikely to do anything other than register the complaint. I haven't seen anything on the net about it, yet.
Subject: Re: [Radiance-dev] MacOS Yosemite
Date: November 18, 2014 8:10:48 AM PST
HI Andreas,
Dear List,
Any suggestions?
Andreas Noback
thank you for the quick response. I suspected that it is a bug from Apple and was hoping that the update today (10.10.1) would change something, but it does not. In general the Yosemite release seems to me buggier that the last couple of major updates, so it could be wise to avoid it for a while ...
Andreas
Am 18.11.2014 um 18:58 schrieb Gregory J. Ward <[email protected]>:
Hi Andreas,
HI Andreas,
Dear List,
Any suggestions?
Andreas Noback
Radiance-dev mailing list
I just received the following from DropBox and it seemed like it *might* be
relevant:
We’re reaching out to let you know about an issue in Apple’s new OS X
Yosemite that causes problems withDropbox. You can resolve this issue by
installing the latest Software Update for OS X Yosemite.
OS X Yosemite may occasionally cause some programs to crash when you open,
save-as, or first save a file. These crashes are rare but happen when an
application, such asDropbox, uses Yosemite’s official Finder integration —
and if that program crashes because of this interaction, unsaved changes
may be lost.
To fix this issue, Apple has released OS X Update 10.10.1. This update is
available for free in the Mac App Store. Details on how to update your Mac
are available onApple’s support site <http://support.apple.com/HT1338>\.
On Tue, Nov 18, 2014 at 10:15 AM, Andreas Noback <[email protected]> wrote:
Andreas
> Hi Andreas,
> Cheers,
> -Greg
>> From: "Gregory J. Ward" <[email protected]>
>> HI Andreas,
worth a try.
>> Best,
>> -Greg
>>> From: Andreas Noback <[email protected]>
>>> Dear List,
(forever):
zombies:
>>> Any suggestions?
>>> Andreas Noback
> [email protected]
Oops, I didn't see Andreas' last e-mail went to my junk folder. Sorry to
hear 10.10.1 doesn't help.
be relevant:
open, save-as, or first save a file. These crashes are rare but happen when
an application, such asDropbox, uses Yosemite’s official Finder
integration — and if that program crashes because of this interaction,
unsaved changes may be lost.
Andreas
> Am 18.11.2014 um 18:58 schrieb Gregory J. Ward <[email protected] >> >:
> Hi Andreas,
> Cheers,
> -Greg
>> HI Andreas,
worth a try.
>> Best,
>> -Greg
>>> Dear List,
(forever):
zombies:
>>> Any suggestions?
>>> Andreas Noback
> [email protected]
is this problem still existent ? We are currently re-installing several mac-machines and I'm wondering if I still should go for Maverick to avoid this problem.
thanks!
Jan
Am 11/18/14 um 7:15 PM schrieb Andreas Noback:
Andreas
Hi Andreas,
HI Andreas,
Dear List,
Any suggestions?
Andreas Noback
Dr.-Ing. Jan Wienold
EPFL ENAC IA LIPID
LE 1 111 (Office)
Phone +41 21 69 30849
Hi Jan,
It's really difficult to find any information on low-level system calls in Mac OS X. Unfortunately, searching for "select" comes up with many irrelevant hits, and bug fixes tend to list applications and behavior rather that root causes. The only really way to tell if the bug has been fixed is to update to the latest version of Yosemite on one machine and run some tests using rpiece to see if it hangs. (It's easy enough to test by running "rad -N 4 -v 1 scene.rif" or similar.)
I can perform such a test tomorrow or the next day if no one else has a current version of Yosemite to try it on. I'm still running Lion, which is the *oldest* version of Mac OS X that my laptop supports....
Date: July 24, 2015 2:36:52 AM PDT
thanks!
Jan
Andreas
Hi Andreas,
HI Andreas,
Dear List,
Any suggestions?
Andreas Noback
EPFL ENAC IA LIPID
LE 1 111 (Office)
Hi Jan,
I went ahead and tried it out, and can confirm that as of Yosemite 10.10.4 (the latest), multi-processing is still very seriously broken. Processes freeze and you are forced to kill them as the only remaining option.
The good news is that multi-processing seems to work find under Mavericks. I ran the same test and didn't encounter any problems. I recommend that no one using Radiance upgrade past 10.9 at this stage.
Date: July 24, 2015 9:04:58 AM PDT
Hi Jan,
thanks!
Jan
Andreas
Hi Andreas,
HI Andreas,
Dear List,
Any suggestions?
Andreas Noback
EPFL ENAC IA LIPID
LE 1 111 (Office)
thank you so much for your test- so we will install Mavericks on all our machines now.
yes, I can confirm that Mavericks works fine regarding multiprocessing (since my desktop machine has it installed as well and I often use rtrace -n ...).
It is also a wise decision to keep older systems as long as possible - some simple tools are harder to install on the newer systems. E.g. it took me several hours to install the netpbm - package (e.g. for pnmtojpeg ) on Mavericks (but got it finally by the usage of macports).
thanks again!
cheers,
Jan
On 07/24/2015 09:12 PM, Gregory J. Ward wrote:
Hi Jan,
Hi Jan,
thanks!
Jan
Andreas
Hi Andreas,
HI Andreas,
Dear List,
Any suggestions?
Andreas Noback
EPFL ENAC IA LIPID
LE 1 111 (Office)
EPFL ENAC IA LIPID
LE 1 111 (Office)
