Luxhour and sunhour reenderings
Hi everybody,
Does somebody know how to produce a rendering highlighting annual sunhours or luxhours, if possible combined with a file with cloudiness factors of a Test Reference Year for a certain location ???
I don't even know where to start !
Jochen
________________________________________________________________________
This e-mail has been scanned for all viruses by Star Internet. The
service is powered by MessageLabs. For more information on a proactive
anti-virus service working around the clock, around the globe, visit:
Hi Jochen,
There are several annual daylight simulation tools that use Radiance. Two of these are DAYSIM (http://irc.nrc-cnrc.gc.ca/ie/light/daysim.html\) and the Dynamic Lighting System (http://www.iesd.dmu.ac.uk/~pcc/dls/\). They both use similar techniques (daylight coefficients), but run in different ways. Both are free to download.
I haven't used DLS, but have DAYSIM, and it's a pleasure to use. it can give you daylight illuminances at given points for every hour (or more often) of the daylit year. you can also set a threshold level and it will provide daylight autonomies at the given points. daylight autonomy describes how often the natural illumination at a point exceeds the threshold value. with the hourly (or more often) daylight illuminances, you can calculate your annual luxhours.
John Mardaljevic's web site (Institute of Energy and Sustainable Development) also describes an algorithm for predicting solar penetration. this will give you annual sunhours, or equivalent. the algorithm isn't yet available, but contact John if you'd like more info.
good luck!
Phil.
Phillip Greenup
Specialist Engineer
Arup Australasia
Level 10, 201 Kent St
Sydney NSW 2000
Ph (02) 9320 9426
Fax (02) 9320 9321
[email protected] 10/07/2003 11:54:43 pm >>>
Hi everybody,
Jochen
Hello Jochen,
I have done such kind of RADIANCE calculations by using "annual mean skies" models produced from hourly beam and diffuse irradiance data (obtained from the METEONORM software). Here is a stereographic projection showing the annual mean sky for Fribourg (Switzerland) using a falsecolor scale that maps the radiance values:
Fribourg_msky00.tif radiance_scale.tif
The sky vault is subdivided in 145 zones as defined by the CIE.
The corresponding RADIANCE scene file (F00.rad) is attached hereafter with the generic treg_sky.rad file. As indicated at the beginning of the file, the mean radiance values are computed over the daylit hours only. If you make a RADIANCE simulation under such a sky model (using rpict option -i), you get mean irradiance values in [W/m2]. If you want irradiation values in [Wh/m2], you just need to multiply the results by the number of hours indicated at the beginning of the file.
Note that in this sky model, the red, green and blue channels contain respectively diffuse, direct and total mean radiance values. To extract one of this component filter your picture like that:
to get the direct irradiance only: pcomb -e 'lo=gi(1)' original_picture.pic >direct_only.pic
or to get the total irradiance: pcomb -e 'lo=bi(1)' original_picture.pic >total.pic
Of course, due to this "unusual" way of using the RGB channels, it is not possible to use such a sky model with coloured materials. Such models have to be used with "gray" surfaces where the r,g,b materials parameters are the same (=surface overall reflectances).
With a similar approach I also prepared a mean sky model for daylighting studies (F00dl.rad). For such a model only the working hours (from 8am to 6pm) are averaged. The daylight saving time period is also considered. Again if you make a RADIANCE simulation under such a sky model (using rpict option -i), you directly get mean illuminance values in [lx].
If you want light exposure values in [lx hours], then just multiply the results by the number of hours considered in the model. The model uses the same RGB channels separation as explained above.
Hope this can help you.
R. Compagnon
F00.rad (7.85 KB)
F00dl.rad (7.87 KB)
treg_sky.rad (15.3 KB)
Dr. Raphael Compagnon
University of Applied Sciences of Western Switzerland (HES-SO)
Ecole d'ingenieurs et d'architectes de Fribourg (EIA-FR)
80 Bd Perolles, 1705 Fribourg Switzerland
Phone:+41 26 429 6666 or +41 26 429 6611 (secretariat)
Fax: +41 26 429 6600
E-Mail: [email protected] WWW: http://www.eif.ch
The pictures included in my previous message are available from:
http://www.eif.ch/~compag/radiance/Fribourg_mean_sky.htm
