Low simulated illuminance levels under direct sun
Hi Krystyna,
Did you use any of the calibration options to gensky (-r, -R, -b, or -B)? If not, then it's surprising that your results are as close as this. If you did use these options, then we should check the conversion factors and what measurements you based them on. Provided you have a separate measure of sun and sky and the rest of the parameters are correct, you should get good agreement with the open-sky test case.
Some good tips on setting gensky parameters may be found in Axel Jacob's Radiance tutorial, which is currently linked at:
  http://luminance.londonmet.ac.uk/learnix/docs/radiance_tutorial.pdf
Date: February 14, 2011 3:16:58 PM PST
I am trying to develop a Radiance model of an actual building. I have
collected hourly global horiz. illum. on roof and vertical illum. on
facade (using a LI-COR sensor) and have been making hourly comparisons
between measured and simulated data. The building is surrounded by
several buildings which block much of the direct sun reaching the
facade - I've included the obstructions in the computer model.
While the simulated global vertical illuminance levels on the facade
are within +/-10% of those measured on site under diffuse light
conditions (much of the light reaching the facade is diffuse due to
heavy exterior obstructions), I am getting a high error when for
simulated vs actual illuminance under direct sun. Under direct sun,
illuminance levels are underpredicted by 30% in the computer model.
The site is Berkeley, CA, and I used the Oakland weather file, so the
location should be very close in terms of latitude/longitude and I
double-checked the facade orientation (8 deg east of South). I
excluded all of the exterior obstructions and compared to illuminance
levels one might expect under direct sun for that orientation using
daylight availability tables for San Francisco and the levels once
again seem low.
Here is a bit more info on the model:
CIE clear sky
-ab 5 -ad 1024 -as 256 -ar 1064 -aa 0.1
Max. dimension of the site/model modeled is 4,200 ft
Does anyone have any idea why illuminance levels under direct sun
might be underpredicted?
Thank you,
Krystyna
I got a response from the DIVA mailing list - the program does not
allow the user to input calibration factors (-r -R -b or -B) for the
gensky command (I chose to use Rhino in combination w/ the plugin
DIVA-for-Rhino since I do not have access to a Unix machine and
because of its user-friendly interface). Will see if I can workaround
this problem as described below.
Thank you,
Krystyna
Dear Krystyna,
DIVA does not pass any calibration factors to gensky from the weather
file. It is called as in the below example,
!gensky 09 21 09 +s -a -16 -o 48 -m 45
You can't put in the calibration factors using -r -R -b or -B as Greg
suggests via the DIVA GUI. However, by editing the filename_sky.rad in
your DIVA temp folder and by running the simulation using
filenameimg.bat you could short-circuit the GUI and add a calibration
flag to the gensky command. Note that every time you run a
visualization from the GUI, you'll need to re-edit the sky.rad file if
you decide to do this.
The other option, if you have direct and diffuse radiation data, is to
use the Perez sky distribution via gendaylit. DIVA has a gui frontend
to this which you can choose by selecting the Perez Sky option under
sky condition in the metrics dialog.
Alstan
On Mon, Feb 14, 2011 at 7:09 PM, J. Alstan Jakubiec <[email protected]> wrote:
On Mon, Feb 14, 2011 at 4:02 PM, Greg Ward <[email protected]> wrote:
Hi Krystyna,
> From: Krystyna Zelenay <[email protected]>
> Hi,
> again seem low.
> CIE clear sky
> Thank you,
> Krystyna
Hi Krystyna,
I haven't had a chance to play around with DIVA myself, but it sounds like an amazing tool! I'm sure the authors will add in some workarounds in future releases for users who need a little more control over their simulations, but in the meanwhile, the gendaylit option Alstan mentions seems like a good one. Let us know how it all turns out.
Date: February 14, 2011 8:02:33 PM PST
Thank you,
Krystyna
Dear Krystyna,
Alstan
