Hi Jan,
Thanks for the pointer. I've downloaded the pmap 4.3 version and tried to compile/install (after performing a fresh installation of radiance 3.7), but the pmap installation is unsuccessful, with the following error messages being generated by 'makeall install' during the
compilation:
../lib/libpmap.a(pmapmat.o)(.text+0xf64): In function `anisoSpecPhotonScatter':
: undefined reference to `getacoords'
../lib/libpmap.a(pmapmat.o)(.text+0x1afb): In function `dielectricPhotonScatter' :
: undefined reference to `mylog'
../lib/libpmap.a(pmapmat.o)(.text+0x1b26): In function `dielectricPhotonScatter' :
../lib/libpmap.a(pmapmat.o)(.text+0x1b51): In function `dielectricPhotonScatter' :
../lib/libpmap.a(pmapmat.o)(.text+0x1db1): In function `dielectricPhotonScatter' :
../lib/libpmap.a(pmapmat.o)(.text+0x1dd9): In function `dielectricPhotonScatter' :
../lib/libpmap.a(pmapmat.o)(.text+0x1e01): more undefined references to `mylog' follow
collect2: ld returned 1 exit status
make: *** [mkpmap] Error 1
make: Target `install' not remade because of errors. ~/rad3R7/ray/src
Do you have any idea of what might be causing this?
Thanks in advance,
Erico
Sent: Saturday, January 14, 2006 1:30 AM
Subject: Re: [Radiance-general] lightpipes/ports
Hi Erico,
you probably should use the current version of photon-mapping(4.3), which is for the RADIANCE 3.7. Roland made this new version some weeks ago.
I'm not sure, if this helps in your special case, but I never had such problems with using photon-ports and I used it several times without any problems (I always used the 3.28 version for RADIANCE 3.5).
We are actually reorganizing our web-pages and unfortunately the English (web)version is not available and the German version shows a bug in direct linking. That's the reason, why I haven't posted it to the community yet.
Anyhow, it is already on a Web-page for downloading.
You can get it on:
http://www.ise.fraunhofer.de/german/fields/field6/mb4/index.html then follow link on "Lichtsimulation", then "RADIANCE", then "p-map"
Good luck!
Jan
Erico Rosa wrote:
I'm running a simulation on hollow mirror lightpipes and I've installed the photon map compiled by Carsten Bauer (at http://www.cb-d.de/pmap/pmap.html\) for Radiance 3.6. I also downloaded the examples from Roland Schregle <mailto:[email protected]>'s webpage (http://www.ise.fhg.de/alt-aber-aktiv/radiance/photon-map/download.html\) to run a "test drive". The Photon Map runs all scripts without any problems until I use the examples with "ports". It falls into what seems a loop where the progress reports give me an exorbitant 30,000% (it's still running...). Will it stop eventually?
Does anybody have worked with the ports option and bumped into this abnormal behaviour?
Erico
[email protected] <mailto:[email protected]>
Dipl.-Ing. Jan Wienold
Project Manager
Fraunhofer-Institut f�r Solare Energiesysteme
Thermal Systems and Buildings, Lighting and Daylighting
Phone: +49(0)761 4588 5133 Fax:+49(0)761 4588 9133
In office:
Mo,Tue: 9:00-18:00
We-Fr: 8:30-14:00
