As a theoretical exercise I am trying to generate a Radiance image (via
Ecotect) of daylight bouncing off a light shelf in a room (30'w x 10.5'h x
60' deep) where the light shelf (top surface), ceiling and the floor are
mirror surfaces (100% reflective and 100% specular) while the walls are non
reflecting black. I have been unsuccessful, so far, to generate more than
two reflections. I would appreciate any help in generating the 3rd, 4th
and subsequent reflections. I would be happy to send images to anyone
interested.
Shamim Javed
PhD Candidate
College of Architecture and Urban Studies
Virginia Tech
Are you using the default parameters for rpict/rtrace? Have you tried setting the -dr parameter greater than 2? If you post the command you are using to calculate the reflections, it may be easier to comment. I suspect it will be more complicated than the -dr setting, but that's a start.
I have been unsuccessful, so far, to generate more than two reflections.
I am using Radiance via Ecotect. I have played around with changing the
values for -dr, -av and -ab without seeing any change in the image output.
On Mon, Mar 11, 2013 at 9:20 AM, Christopher Rush <Christopher.Rush@arup.com > wrote:
reflections.
Hi Shamim,
What changes are you expecting to see?
Jack de Valpine
President
Visarc Incorporated
www.visarc.com
channeling technology for superior design and construction
On 3/11/2013 10:03 AM, Shamim Javed wrote:
I am using Radiance via Ecotect. I have played around with changing the values for -dr, -av and -ab without seeing any change in the image output.
On Mon, Mar 11, 2013 at 9:20 AM, Christopher Rush > <Christopher.Rush@arup.com <mailto:Christopher.Rush@arup.com>> wrote:
reflections.
<mailto:Radiance-general@radiance-online.org>
I am hoping to see multiple reflections of the light beam reflected off the
light shelf top surface in both the floor and the ceiling (all of which are
mirror surfaces).
On Mon, Mar 11, 2013 at 10:40 AM, Jack de Valpine <jedev@visarc.com> wrote:
Hi Shamim,
Jack de Valpine
President
Visarc Incorporatedwww.visarc.com
On Mon, Mar 11, 2013 at 9:20 AM, Christopher Rush < > Christopher.Rush@arup.com> wrote:
reflections.
Radiance-general mailing listRadiance-general@radiance-online.orghttp://www.radiance-online.org/mailman/listinfo/radiance-general
