Testing an asimetric photometric file with rview appears these light leaks www.aisarquitectura.com\archivos\phot.jpg , i've found them in several tests i don't know if it can be a parameters error or a ies problem...
here it's the ies source www.aisarquitectura.com\archivos\bega.ies
saludos
ignacio
Ignacio, If you read the IES file in a text editor, you will see the
bottom portion of the file is mostly 0 values, but with several 0.1 and
0.2 mixed in. This is either erratic values in the photometry, or
demonstration of actual light leaks from the fixture as it was measured.
It does not appear to be a result of any Radiance parameters.
-Chris
[mailto:[email protected]] On Behalf Of
Ignacio Munarriz
Sent: Monday, 04 February, 2008 7:50 AM
Subject: Re: [Radiance-general] light leaks
problem...
saludos
ignacio
