Hi Greg, everyone,
From the 3.8 Release Notes:
"Renamed librt.a to librtrad.a, to avoid conflict on Solaris. Almost
everything now gets linked to -lrtrad instead of -lrt."
I just tried compiling the new source on a SuSe box here, and got a bunch of "cannot find -ltrad" errors. Do I need to be doing something different, here?
Hi Rob,
You're not the first to make the mistake of using Windows in a misguided attempt to get some work done...
End of line in Unix is "line-feed" (hex 0A), "carriage-return" (hex 0D) in pre-X MacOS, and carriage-return followed by line-feed in Windows (inherited from DOS, inherited from CP/M). This has caused more headaches over the years than just about all the other divergent standards combined, including the '/' '\' stupidity between DOS/VAX and Unix.
Date: October 26, 2006 4:13:49 PM PDT
Gregory J. Ward wrote:
Hi Rob,
This is really peculiar, and I don't know how it got in there, but the backslash on a line by itself should actually be on the line just above it. Somehow, the name of LIBDIR got mangled or got a line-feed or carriage-return stuck in there. Just take it out, and try running "rmake install" in the src/common directory again to see if that fixes it.
Well then I got a bunch of "no rule to make target" errors. Hmmm. I started over, and it wanted to make another botched rmake script. This time I corrected the script before makeall ran, and it worked, but I still got a couple of "no rule" errors. I think the problem is that I unpacked the source archive using a Windows utility (sorry). I will try this all over again from the shell.
(tried)
Yeah, I'm an idiot. Once I unpacked the source from Linux, and re-issued makeall install, it worked as advertised. Imagine that! Thanks Greg, sorry for the trouble.
Hi Rob,
Ha!
Cool, thanks for the education on the various EOL variants, but I'm really a lot more excited about the fact that my calling myself an idiot is now a matter of public record, on the radiance-online archives. Excellent! =8-)
On Oct 26, 2006, at 5:23 PM, Gregory J. Ward wrote:
