learnix installation
Hi All,
How can I get learnix copy? And is learnix much different/better than knoppix itself for running radiance?
Regards
ikrima
Sent: 16 June 2015 14:50
Subject: Radiance-general Digest, Vol 136, Issue 19
When replying, please edit your Subject line so it is more specific than "Re: Contents of Radiance-general digest..."
Today's Topics:
   1. Re: Errors while transposing with Rcollate. (Greg Ward)
   2. Re: Errors while transposing with Rcollate.
      (David Geisler-Moroder)
Message: 1
Date: Mon, 15 Jun 2015 21:58:40 -0700
Subject: Re: [Radiance-general] Errors while transposing with
  Rcollate.
Content-Type: text/plain; charset="windows-1252"
Anyone else have any ideas or suggestions? Honestly, I don't know why redirecting stdin from a file would fail completely. I thought this was supported under Windows.
I'm stumped.
-G
Subject: Re: [Radiance-general] Errors while transposing with Rcollate.
Date: June 15, 2015 9:45:56 PM PDT
The command that you suggested returns the usage options for rcollate
in windows. (ie. Usage: rcollate [-h[io]???..)
Earlier, I had tried feeding the file to rcollate via stdin through using pipe ( | ) as well as the ?type a.txt? shell command in windows but didn?t get it work either way.
Sarith
Sent: Tuesday, June 16, 2015 12:04 AM
Hi Sarith,
This seems related to the broken handling of text versus binary files under Windows. Try reading the file from stdin, instead:
rcollate ?h ?fa1 ?t < a.txt > d.txt
If this works, let me know and I'll see if I can put in a fix.
Subject: [Radiance-general] Errors while transposing with Rcollate.
Date: June 15, 2015 5:09:13 PM PDT
Hi everyone,
I am trying to do a transpose with rcollate. My operating system is Windows. My file contains rgb triplets arranged in a (8760columns x 60rows) matrix. I either get a ?error loading file into memory? or an incorrect transpose.
I found that I got the same results with a simple ASCII file with tab separated values. My file contains:
1 2 3 4
5 6 7 8
9 10 11 12
The following commands return ?error loading file into memory?:
rcollate ?h ?fa1 ?t a.txt >d.txt
rcollate ?h ?fa1 ?ic 4 ?oc 3?t a.txt >d.txt
I found that the ?-t? flag was responsible for the error, so I tried explicitly stating the values for columns and rows as:
rcollate ?h ?fa1 ?ic 4 ?ir 3 ?oc 3 ?ir 4 a.txt>d.txt
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Am I missing something?
Sarith
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20150615/b9ed1f79/attachment-0001.html&gt;
Message: 2
Date: Tue, 16 Jun 2015 15:50:19 +0200
  Rcollate.
Message-ID:
  <CAL-bo5Gfz3PRp=qPWFVVagLXZiqKU_-7S6t4Xkr4nj_CYfO8aQ@mail.gmail.com>
Hi Sarith,
I just tried both calls (with and w/o redirecting from stdin) with the latest Windows binaries from NREL(https://github.com/NREL/Radiance/releases\)
and both work fine at my side...
rcollate ?h ?fa1 ?t a.txt > d.txt
Which version of rcollate are you using?
David
2015-06-16 6:58 GMT+02:00 Greg Ward <[email protected]>:
I'm stumped.
-G
*Subject: *Re: [Radiance-general] Errors while transposing with Rcollate.
*Date: *June 15, 2015 9:45:56 PM PDT
Sarith
*Sent:* Tuesday, June 16, 2015 12:04 AM
*Subject:* Re: [Radiance-general] Errors while transposing with Rcollate.
Hi Sarith,
*Subject: *[Radiance-general] Errors while transposing with Rcollate.
*Date: *June 15, 2015 5:09:13 PM PDT
Hi everyone,
1 2 3 4
5 6 7 8
9 10 11 12
*rcollate ?h ?fa1 ?t a.txt >d.txt*
*rcollate ?h ?fa1 ?ic 4 ?oc 3?t a.txt >d.txt*
*rcollate ?h ?fa1 ?ic 4 ?ir 3 ?oc 3 ?ir 4 a.txt>d.txt*
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Sarith
Dipl.-Ing. Dr. David Geisler-Moroder
Hofwaldweg 14/20
6020 Innsbruck
Austria
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20150616/9e09e6b0/attachment.html&gt;
End of Radiance-general Digest, Vol 136, Issue 19
This message and any attachment are intended solely for the addressee
and may contain confidential information. If you have received this
message in error, please send it back to me, and immediately delete it.
Please do not use, copy or disclose the information contained in this
message or in any attachment. Any views or opinions expressed by the
author of this email do not necessarily reflect the views of the
University of Nottingham.
This message has been checked for viruses but the contents of an
attachment may still contain software viruses which could damage your
computer system, you are advised to perform your own checks. Email
communications with the University of Nottingham may be monitored as
permitted by UK legislation.
Hi Ikrima,
I'm afraid LEARNIX is no longer maintained. You can still download the ISO image from here: http://www.jaloxa.eu/mirrors/learnix/index.shtml
but be aware that the latest release is from 2011.
Chances are that if you run it on hardware later than 2011, you will get problems, which are most likely to show up with weird display issues, or networking hardware not working.
To add insult to injury, the copy of Radiance that comes with this old LEARNIX CD-ROM is from, well... 2011.
You are much better off trying out a bootable UBUNTU CD-ROM or DVD. If you read the 'Running LEARNIX' PDF, available under 'Documentation', you'll find a number of different ways of running LINUX alongside or within Windows.
Installing Radiance from the standard Debian or Ubuntu repositories is fairly straight-forward.
Hope you will succeed with you endeavour.
Best
Axel
On 16/06/15 17:32, Ikrima Amaireh wrote:
Hi All,
Regards
ikrima
Today's Topics:
Message: 1
  Rcollate.
I'm stumped.
-G
Sarith
Hi Sarith,
Hi everyone,
1 2 3 4
5 6 7 8
9 10 11 12
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Sarith
Message: 2
  Rcollate.
Message-ID:
Hi Sarith,
David
I'm stumped.
-G
Sarith
Hi Sarith,
Hi everyone,
1 2 3 4
5 6 7 8
9 10 11 12
This gave me.
1 2 3
4 5 6
7 8 9
10 11 12
Sarith
Hofwaldweg 14/20
6020 Innsbruck
Austria
Axel,
The Radiance package in Learnix may be outdated, but I think the standard Ubuntu packages aren't much better. Looks like Radiance 4R1 from 2012:
http://packages.ubuntu.com/search?suite=all&searchon=names&keywords=radiance
Picking a more current version from the NREL github seems to be the most user-friendly method to get the current version (even then you'll have to decide if you stick to the "latest release" version 4.2.2 from 2014 or to get the most recent bug fixes that are in all the successive versions following that).
Hi Chris,
thanks for pointing this out. I tend to compile Radiance from source
on all of my machine, which is why I didn't realise it is no longer
maintained as a Debian/Ubuntu package. Debian's package tracker lists
it as removed from Testing: https://tracker.debian.org/pkg/radiance
According to the package tracker, the following actions are needed:
- Does not build reproducibly during testing
- The package has not entered testing even though the delay is over
- The package depends on source packages which need a new maintainer.
- lintian reports 278 warnings
- Build log checks report 2 warnings
So that's probably the end of it :frowning:
Best
Axel
On 17 June 2015 at 14:13, Christopher Rush <[email protected]> wrote:
Axel,
Ubuntu – Package Search Results -- radiance
