Hi Folks,
I would be grateful if anyone would provide some insight to a problem I've
been trying to resolve for some time:
I am using fluorescent lamps in an office scene, and would like to model
colour temperatures of approx. 2200K and 6000K giving a warm white and
daylight white respectively.
I have read through the Radiance manual but am a little confused still as to
how to set lamp format file (.fmt) to give me the required colours.
I have generated a .dat file from the ies data for the lamp within which I
set the colour to the default set at 0.907 0.863 0.4762: I believe that this
represents 48 46 25% RGB values.
However, when I run a lighting illuminance simulation the .lum file refers
only to the lamp .dat file and .fmt file (not the .rad file generated by
ies2rad). Now upond exploring the .fmt file it refers to the 'void lamp
glow' in this instance its: 4 0 3.57 14.72 860
I think that this may be the line I need to change to alter the colour?
Unless it's already taken care of in the ies2rad conversion via the .dat
file in which case I need to alter the 0.907 0.863 0.4762 values relative to
desired K values. I'd be indebted to anyone that can provide the relevan
combination for the two lamp colours I'm looking for.
With kind regards,
Anthony Farrell
Dublin Institute of Technology
[mailto:[email protected]] On Behalf Of
Sent: 19 May 2005 16:34
To: [email protected]
Subject: Radiance-general Digest, Vol 15, Issue 11
When replying, please edit your Subject line so it is more specific than
"Re: Contents of Radiance-general digest..."
Today's Topics:
1. Redirecting+scattering (Federico Giovannetti)
2. Re: Redirecting+scattering (Greg Ward)
3. Re: Redirecting+scattering (Jan Wienold)
4. RE: Redirecting+scattering (Giulio Antonutto)
Message: 1
Date: Thu, 19 May 2005 15:24:09 +0200
Subject: [Radiance-general] Redirecting+scattering
To: <[email protected]>
Message-ID: <002801c55c76$0a260f90$e400a8c0@PC501fg>
Hallo Greg Ward, hallo Radiance Community!
I've been learning Radiance for a couple of weeks and i have to work
intensively with it in the next weeks, as I4m investigating the energy
saving potential and visual comfort of systems combining angular selective
and diffusing panes.
Now I have to simulate a simple test-room with a complex fenestration, which
includes an exterior prismatic structure as shading device and a diffusing
pane for glare control. I try to find out the best way to model the system
so as to get quantitative accurate results (RwR Chapters 10-13 and mails
archive) but i4m still a little bit confused....
- As to the prismatic structure, i will use the PRISM2 material as virtual
source. No redirection of diffuse incoming light and no dispersion are the
only limitations of this material. And it would make no sense to use the
PhotoMap port, because these materials are not implemented in this tool. Is
it right?
- As to the diffuser, i would intuitively treat it as an ILLUM with a BRTDF
function as alternate material (I4m measuring, modelling and comparing
different kind of diffusers) and run MKILLUM. If i understood correctly,
the BRTDF materials are only considered in the direct calculation and
indirect specular, but not in the indirect diffuse, where they are
approssimate to lambertian diffusers. Should i try another material?
- How are PRISM materials computed in the MKILLUM calculation of the window
light output? Should I better try to run the simulation without MKILLUM and
high ambient parameters (-ab, -ad, -as)?
- What if i measure the BRTDF of the complete system and i model it as a
normal light source? It is really difficult (or impossible) to get sharp
peaks in light output with high subsampling and jittering of the source?
Any other suggestion to simulate this system correctly (quantitative)?
Sorry for so many questions and THANKS A LOT for any contribution.
Institut f|r Solarenergieforschung GmbH
Am Ohrberg 1
D-31860 Emmerthal
tel: +49(0)5151-999-501
fax: +49(0)5151-999-500
e-mail: [email protected]
internet: www.isfh.de
URL:
http://radiance-online.org/pipermail/radiance-general/attachments/20050519/2
9880a28/attachment.html
Message: 2
Date: Thu, 19 May 2005 08:08:13 -0700
Subject: Re: [Radiance-general] Redirecting+scattering
Content-Type: text/plain; charset=ISO-8859-1; delsp=yes; format=flowed
Hi Federico,
It sounds to me like you are "diving into the deep end" as they say about
new swimmers who are very ambitious.
virtual source. No redirection of diffuse incoming light and no
dispersion are the only limitations of this material. And it would
make no sense to use the PhotoMap port, because these materials are
not implemented in this tool. Is it right?
I don't know about support in the photon map add-on, but the prism material
types do redirect diffuse rays as well. They just don't have a diffuse
component.
BRTDF function as alternate material (I4m measuring,
modelling and comparing different kind of diffusers) and run
MKILLUM. If i understood correctly, the BRTDF materials are only
considered in the direct calculation and indirect specular, but not in
the indirect diffuse, where they are approssimate to lambertian
Your information is correct as far as I understand what you are saying. If
you can fit your measurements to a Gaussian lobe distribution, you are
better off using one of the native models
(trans or trans2), as all ray paths will be followed appropriately.
The general BRDF types, transfunc, transdata, and BRTDfunc, only use the
directional-diffuse lobe specified for interactions with light sources.
General ray sampling from an arbitrary distribution is quite expensive, and
not done in Radiance for that reason.
window light output? Should I better try to run the simulation without
MKILLUM and high ambient parameters (-ab, -ad, -as)?
The diffuse portion of the window distribution through a prismatic glazing
will be computed by mkillum, leaving the "specular" (directional) portion to
be done during the final rendering. This is the correct behavior, and you
don't have to treat it specially with mkillum, which is helpful for
considering contributions from the sky, ground, and neighboring structures.
as a normal light source? It is really difficult (or impossible) to
get sharp peaks in light output with high subsampling and jittering
of the source?
I'm not sure what you mean, here. If you have some way to simulate your
exterior and measure the actual output distribution of the window system as
a light source, then you wish to represent that as a brightdata modifier on
a window polygon, this would work. It's a very challenging measurement
problem, though, which is why no one has done it to my knowledge. (Anyone
out there have information on this?)
The purpose of mkillum of course is to create a light source from your
surface(s) by simulating an outdoor situation. It doesn't always work,
though. Specifically, mkillum has trouble resolving the contribution from
the sun through curved, specular reflectors and devices. It can handle most
everything else.
(quantitative)?
Measure and validate. Repeat.
Message: 3
Date: Thu, 19 May 2005 16:07:40 +0200
Hi Federico,
your task cries for using photon-mapping...
You should model your shading system geometrically and use dielectric as
material (be careful about the surface orientation!). The diffusing material
can be modeled by trans material. If you have a complex scattering material,
you can adapt the trans material by an cal function. (Don't use BRTF-func or
data with the current photon-mapping version).
To be more efficient using the diffuse sky, you should define a photon-port,
where all the photons are emitted to. Usually the photon-port material is
the window pane.
Then you can simply run the simulations, direct and diffuse contributions
should be calculated correctly.
Last but not least, there exist also a version of daysim containing
photon-mapping, so you can run these simulations also hourly (or other
timesteps) if you want. Unfortunately, the latest daysim version didn't
compile with the photon-mapping extension - but if you need it, you can use
also the older version, Christoph could provide it.
Good luck!
Jan
selective and diffusing panes.Now I have to simulate a simple test-room with a complex fenestration,
which includes an exterior prismatic structure as shading device and a
diffusing pane for glare control. I try to find out the best way to
model the system so as to get quantitative accurate results (RwR
Chapters 10-13 and mails archive) but i4m still a little bit confused....- As to the prismatic structure, i will use the PRISM2 material as
not implemented in this tool. Is it right?- As to the diffuser, i would intuitively treat it as an ILLUM with a
BRTDF function as alternate material (I4m measuring, modelling and
comparing different kind of diffusers) and run MKILLUM. If i
understood correctly, the BRTDF materials are only considered in the
direct calculation and indirect specular, but not in the indirect
diffuse, where they are approssimate to lambertian diffusers. Should i
try another material?- How are PRISM materials computed in the MKILLUM calculation of the
MKILLUM and high ambient parameters (-ab, -ad, -as)?- What if i measure the BRTDF of the complete system and i model it as
a normal light source? It is really difficult (or impossible) to get
sharp peaks in light output with high subsampling and jittering of
the source?Any other suggestion to simulate this system correctly (quantitative)?
Federico Giovannetti---------------------------------------------------------
Institut f|r Solarenergieforschung GmbH Am Ohrberg 1 D-31860 Emmerthaltel: +49(0)5151-999-501
e-mail: [email protected] <mailto:[email protected]>
internet: www.isfh.de <http://www.isfh.de>-----------------------------------------------------------------------
-_______________________________________________
URL:
http://radiance-online.org/pipermail/radiance-general/attachments/20050519/b
f64c462/attachment.htm
Message: 4
Date: Thu, 19 May 2005 16:31:09 +0100
Subject: RE: [Radiance-general] Redirecting+scattering
To: "Radiance general discussion"
<[email protected]>
Message-ID:
<[email protected]>
you may also consider to have a look to radzilla
This is a not official, not bullet proof, version of radiance that
incorporates all new additions + some really crazy Carsten
optimisations/changes/addons...
It seems really consistent and stable and I already modelled some prisms
with pmap within it (like a 500 modular prisms wall).
It works well!
I believe it's worthy to try and I have been really impressed by the latest
development.
The advantage over traditional radiance for me is that photon mapping is
performed through the rpict command without having to use mkpmap... but they
might be some bugs here of there.... watch out!
ciao,
giulio
[mailto:[email protected]] On Behalf Of Federico
Giovannetti
Sent: 19 May 2005 14:24
it right?
Am Ohrberg 1
D-31860 Emmerthal
URL:
0a30c86/attachment.html
End of Radiance-general Digest, Vol 15, Issue 11
This message has been scanned for content and viruses by the DIT Information
Services MailScanner Service, and is believed to be clean.
http://www.dit.ie
viruses by the DIT Information Services MailScanner
http://www.dit.ie
