Excuse me, but, I am doing one exercise that is from the other team and I
do not know how the file.xml was get. Shortly I will start with my own case
study and I will use /genBSDF/ command and WINDOW 7.3 program to get the
files.xml.
Thank you for your attention.
Best wishes,
Urtza.
Greg Ward <[email protected]> escribió:
Hi Urtza,
You make it challenging to help you when you provide so little
information in your posts. This forces folks to ask silly follow-up
questions, like "Where did you get your XML file and what is in it?"
Judging by the filename, it looks like it uses a non-standard (and
non-square) BTDF matrix, which probably won't work with dctimestep.
That would make sense with the error you are seeing, but it can be no
more than a guess without further clues from you.
SUBJECT: Re: [Radiance-general] Klems_full.cal: -b kbin(S-E)
DATE: May 27, 2015 6:07:35 PM GMT+02:00
"kbin(0.7,-0.7,0,0,0,1)" and -b "kbin(sqrt(.5),-sqrt(.5),0,0,0,1)" work.
Thanks!
On the other hand, I have other problem with file.xml because with other
VenetianBlind.xml file works:
C:\Users\Urtza\Desktop\AIE50\CFS>dctimestep results/photocellsRotated45.vmx
data
/Lasercut_Panel_145x1297.xml results/south.dmx Geneva.smx >
results/illum_lp.dat
fatal - unexpected column count in header
Does anyone know what happen?
Thank you a lot,
Urtza.
The missing comma generated your error, but you'll get some other errors
if you don't pass kbin a normalized vector. Use:
instead.
DATE: May 27, 2015 5:40:56 PM GMT+02:00
What I am going to try does not come from the error message (because I
see the modifier there)... try putting the KBIN() between ""... that is
-b kbin(0.7,-0.7,0,0,0,1) --> -b 'kbin(0.7,-0.7,0,0,0,1)' -- or --> -b
Also, I see you are missing a comma there...
Bye!
_-vd works well. However -b kbinSE, error:
C:\Users\Urtza\Desktop\AIE50\CFS>perl
c:/radiance/bin/genklemsamp.pl[1] -vd 0.70 -0_
_.70 0 objects/window.rad | rcontrib -c 1000 -e MF:4 -f
reinhart.cal -b rbin -bn_
_Nrbins -m sky_glow after_dmx.oct > results/south.dmx
/(Works)/
_
_C:\Users\Urtza\Desktop\AIE50\CFS>rcontrib -f
c:/radiance/lib/klems_full.cal -b k_
_bin(0.7,-0.7,0 0,0,1) -bn Nkbins -m windowglow -I+ -ab 2 -ad
512 -lw 2e-5 after__
_vmx.oct < after.pts > results/photocellsRotated45.vmx_
_rcontrib: fatal - missing required modifier argument_
_"Guglielmetti, Robert" <[email protected]> escribió:_
_Er, "0.7 -0.7 0.0" is correct. What you have there is correct. So
what's
going on for you?
On 5/27/15, 8:54 AM, "Guglielmetti, Robert"
<[email protected]>
wrote:_
_Hi Urtza,
You can definitely put in the normal manually, and 0.7 0.7 0.0 is
correct
for SE-facing window. What happened (or didn't happen)?
Hello experts,
I am trying to get Illuminance data by The Three-Phase Method of
East 45º
rotated room. The window faces South-East. Is it possible?
· Can I put by hand -b kbin(Nx,Ny, Nz, Ux, Uy,Uz)? I try but it
seems it
does not work.
· I put, -vd 0.70 -0.70 0 Does it make sense?
Thank you in advance.
Kind regards,
Urtza._
Vínculos:
2015-05-27 12:30 GMT-03:00 <[email protected]>:
On 5/27/15, 8:27 AM, >>>>> "[email protected]<mailto:[email protected]>[2]" >>>>> <[email protected]<mailto:[email protected]>>[3] wrote:
[1] http://genklemsamp.pl
[2] mailto:[email protected]%3E
[3] mailto:[email protected]%3E%3E
