irradiance calc that ignores incident angle
I'm curious if anyone knows of a way to simulate a sensor point that has a
constant response (not cosine corrected) for all incident angles (at least
over a hemisphere). I know I can do this with an angular fisheye image and
I assume I could use rsensor, but i would like a way to do this with a
single rtrace or rpict calculation. Applications include:
1. measuring direct normal irradiance (when I know the source is small
(cos(x) ~ 1), but not the incident angle.
2. calculating percent of a sky/source description that is visible from a
point.
The one though I have is to place an analysis plane with a BRTDfunc
material assigned and then do a radiance calc looking at the plane, but
this only works for the 1st case, where it is part of the direct
calculation. For the second case I tried making a bsdf with bsdf2ttree (or
bsdf2klems) but it seems to introduce a lot of sampling error and doesn't
appear to be working quite right.
BRTDfunc approach:
#cal file:
r(x,y,z) = 1/(x*NxP+y*NyP+z*NzP)/PI;
#material:
void BRTDfunc test
10 0 0 0 0 0 0 r r r test.cal
9 0 0 0 0 0 0 0 0 0
BSDF approach:
#cal file:
rdif(ix,iy,iz,ox,oy,oz) = if(oz*iz,1/(ix*ox+iy*oy+iz*oz)/PI,0);
#bsdf2ttree:
bsdf2ttree -t3 -g 7 -forward -f test.cal rdif > test.xml
#material:
void BSDF test
6 0 test.xml 0 1 0 .
Either way, this feels like an inelegant approach, so anyone have a better
idea or a way to get this working for a diffuse calculation?
Stephen Wasilewski
*LOISOS *+* UBBELOHDE*
Alameda, CA 94501 USA
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com
Hi Stephen,
The simplest method is to use rsensor to generate a set of uniformly distributed rays over the hemisphere, which you can re-use as often as you like. The sensor file below specifies a uniform distribution out to 90°, and even samples a few rays below the horizon Let's call it "uniform.dat":
degrees 0 90 180 270
0 1 1 1 1
5 1 1 1 1
85 1 1 1 1
90 1 1 1 1
95 0 0 0 0
You can run rsensor on the above file and either use it to call rtrace, or since you seem to want to call rtrace yourself, create instead a set of sample rays:
  rsensor -h -rd 100000 -vp 0 0 0 -vd 0 0 1 -vu 0 1 0 uniform.dat > uniform_znorm_samp.txt
You can then give this as input to rtrace with whatever model you like:
  rtrace -h [options] octree < uniform_znorm_samp.txt | total -m
I've passed the output to total with the -m option, assuming you just want the average result. If you're willing to call rsensor in place of rtrace, you can shorten the calculation time with:
  rsensor -rd 100000 -vp 0 0 0 -vd 0 0 1 -vu 0 1 0 uniform.dat [rtrace options] octree
This has the added advantage of sampling light sources directly (unless you set -dn 0), and it even supports the -n multiprocessing option on Unix. You will need to divide the result by the hemispherical solid angle (2π), or else change all your sensor file values by 1/(2π) to get a uniform average.
I did spent quite a bit of time writing and debugging rsensor for just this sort of thing, so you may as well use it. (Thanks to Zack Rogers for specifying the problem and funding the initial work, and to David Geisler-Moroder for doggedly testing the code & helping me sort out its many issues.)
Date: June 30, 2017 4:18:34 AM GMT+06:30
I'm curious if anyone knows of a way to simulate a sensor point that has a constant response (not cosine corrected) for all incident angles (at least over a hemisphere). I know I can do this with an angular fisheye image and I assume I could use rsensor, but i would like a way to do this with a single rtrace or rpict calculation. Applications include:
1. measuring direct normal irradiance (when I know the source is small (cos(x) ~ 1), but not the incident angle.
2. calculating percent of a sky/source description that is visible from a point.
The one though I have is to place an analysis plane with a BRTDfunc material assigned and then do a radiance calc looking at the plane, but this only works for the 1st case, where it is part of the direct calculation. For the second case I tried making a bsdf with bsdf2ttree (or bsdf2klems) but it seems to introduce a lot of sampling error and doesn't appear to be working quite right.
BRTDfunc approach:
#cal file:
#material:
void BRTDfunc test
9 0 0 0 0 0 0 0 0 0
BSDF approach:
#cal file:
#bsdf2ttree:
#material:
void BSDF test
Either way, this feels like an inelegant approach, so anyone have a better idea or a way to get this working for a diffuse calculation?
Stephen Wasilewski
LOISOS + UBBELOHDE
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com
Greg,
the reason I want to call rtrace is because I want to run the uniform
distribution for a large number of points/pixels
is there a way to feed a points file into either of your example commands
to run the sensor for all points (and accumulate result for each point).
I'm looking to be able to do something like this:
rtrace -n 8 -ffc -w -I -ov -x 3000 -y 1163 -ld- [options] test.oct <
test.pts > test.hdr
or
vwrays -fa refs/L2.hdr refs/L2.zbf | rcalc -of -e
'$1=$1;$2=$2;$3=$3+2.5;$4=0;$5=0;$6=if($3-1,1,0)' | rtrace -n 8 -ffc -w -I
-ov -x 3000 -y 1163 -ld- [options] test.oct > test.hdr
and have it run fairly quickly, but with a uniform distribution.
thanks,
Stephen Wasilewski
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com
On Thu, Jun 29, 2017 at 7:20 PM, Greg Ward <gregoryjward@gmail.com> wrote:
Hi Stephen,
0 1 1 1 1
5 1 1 1 1
85 1 1 1 1
90 1 1 1 1
95 0 0 0 0
sample rays:
options] octree
average.
many issues.)
*Date: *June 30, 2017 4:18:34 AM GMT+06:30
point.
BRTDfunc approach:
#cal file:
#material:
void BRTDfunc test
9 0 0 0 0 0 0 0 0 0
BSDF approach:
#cal file:
#bsdf2ttree:
#material:
void BSDF test
Stephen Wasilewski
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com
It sounds like you want to be able to specify a list of points and orientations at which to compute this uniform (non-cosine) average. In other words, replacing the -I option in rtrace with something that computes a uniform hemispherical integral.
You could take the first part of your command to generate the points and normals. Then, call rsensor in a loop like so:
vwrays -fa refs/L2.hdr refs/L2.zbf | rcalc -of -e '$1=$1;$2=$2;$3=$3+2.5;$4=0;$5=0;$6=if($3-1,1,0)' > orig_dir.txt
foreach orig_dir ( " `cat orig_dir.txt` " )
  rsensor -n 8 [rtrace options] [-rd $N1] [-dn $N2] -vp $orig_dir[1-3] -vd $orig_dir[4-6] uniform.dat test.oct >> results.txt
end
(I apologize that I don't know the bash syntax for the loop. I never really understood bash.)
If you really, really want to use rtrace, you can instead use the above loop with "." in place of the octree to create a really long list of ray samples, which you can give to rtrace and send it's output again to total using an option to average every N values. The result would be about the same, though rsensor is more accurate/efficient because of the separate source sampling, which you can control with the -dn option.
Date: July 1, 2017 12:25:51 AM GMT+06:30
Greg,
the reason I want to call rtrace is because I want to run the uniform distribution for a large number of points/pixels
is there a way to feed a points file into either of your example commands to run the sensor for all points (and accumulate result for each point). I'm looking to be able to do something like this:
rtrace -n 8 -ffc -w -I -ov -x 3000 -y 1163 -ld- [options] test.oct < test.pts > test.hdr
or
vwrays -fa refs/L2.hdr refs/L2.zbf | rcalc -of -e '$1=$1;$2=$2;$3=$3+2.5;$4=0;$5=0;$6=if($3-1,1,0)' | rtrace -n 8 -ffc -w -I -ov -x 3000 -y 1163 -ld- [options] test.oct > test.hdr
thanks,
Stephen Wasilewski
Hi Stephen,
0 1 1 1 1
5 1 1 1 1
85 1 1 1 1
90 1 1 1 1
95 0 0 0 0
BRTDfunc approach:
#cal file:
#material:
void BRTDfunc test
9 0 0 0 0 0 0 0 0 0
BSDF approach:
#cal file:
#bsdf2ttree:
#material:
void BSDF test
Stephen Wasilewski
Thaks Greg, I ended up trying something like this (correct syntax for
anyone who is curious, the -u 10 allows for a standard input read within
the loop):
while read -u 10 p;
do
rsensor -vp $p -h -rd 100000 -vd 0 0 1 -vu 0 1 0 -n 8 -w -ab 0 uniform.dat
test.oct
done 10<vpts.txt
but it is very slow (since it is making lots of successive calls to rsensor
and has to load the octree into memory each time). Ultimately, I realized
that for my purposes I could just correct the source with 1/cos and then
use rtrace normally.
Stephen Wasilewski
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com
end
*Date: *July 1, 2017 12:25:51 AM GMT+06:30
Greg,
test.pts > test.hdr
or
thanks,
Stephen Wasilewski
Hi Stephen,
0 1 1 1 1
5 1 1 1 1
85 1 1 1 1
90 1 1 1 1
95 0 0 0 0
sample rays:
options] octree
average.
many issues.)
point.
BRTDfunc approach:
#cal file:
#material:
void BRTDfunc test
9 0 0 0 0 0 0 0 0 0
BSDF approach:
#cal file:
#bsdf2ttree:
#material:
void BSDF test
Stephen Wasilewski
