Hi Radiance experts,
I'm new to radiance and I've came across a problem when using the spotlight
as light source in the scene generation.
In radiance manual I see:
direction (-inf:inf),(-inf:inf),(-inf:inf) Min &
Max infinite
any aimed orientation
Which means I could use any vector as an orientation. But when I tried to
use:
void spotlight lightring3
7 2000 2000 2000 60 0 1 0
I get a warning: rpict: warning - invalid spotlight direction for ring
"spot2.downlight3"
I'm not sure which part I did wrong. Could I specify a spotlight with
direction 0 1 0?
Vera
Hi Vera,
I love these sorts of questions, because it means I get to look at code I haven't touched in years...
In this case, I don't think the problem is with your spotlight specification per se. Rather, I believe the vector orientation disagrees with whatever surface you have applied it to. Radiance makes a check to be sure that the spotlight direction is not "behind" the surface you use it with, and this generated an error in your case. Check the geometry you are using with your spotlight, and I think you'll find the problem.
Subject: [Radiance-general] Invalid spotlight direction
Date: June 22, 2014 10:40:16 AM PDT
I'm new to radiance and I've came across a problem when using the spotlight as light source in the scene generation.
Max infinite
Which means I could use any vector as an orientation. But when I tried to use:
I get a warning: rpict: warning - invalid spotlight direction for ring "spot2.downlight3"
I'm not sure which part I did wrong. Could I specify a spotlight with direction 0 1 0?
Vera
That was really helpful. I found the problem was because the surface. Thank
you for the prompt reply!
Vera
On Sun, Jun 22, 2014 at 10:58 AM, Greg Ward <[email protected]> wrote:
Hi Vera,
*Subject: *[Radiance-general] Invalid spotlight direction
*Date: *June 22, 2014 10:40:16 AM PDT
Max infinite
use:
"spot2.downlight3"
direction 0 1 0?
Vera
