I believe you can just delete the install directories to start from new. Or reinstall in a different location. Im pretty new to radiance, so you may want to wait for other feedback.
Sent: Tuesday, January 20, 2015 10:58 AM
Subject: Re: [Radiance-general] Installing Radiance on OS Yosemite_make: *** [serial.unf] Error 127
Hello Brian,
Thank you for the fast response. I will give it a try.
How do I deinstall Radiance to set it a new? I see only the unpacked folder. Is it just by deleting the folder - i guess that would be too easy to be true//
-------- Оригинално писмо --------
От: "Brian Karr" [email protected]
Относно: Re: [Radiance-general] Installing Radiance on OS Yosemite_make: *** [serial.unf] Error 127
До: "'Radiance general discussion'" <[email protected]>
Изпратено на: 20.01.2015 17:46
Not sure if this applies, when I installed on Mac this thread helped:
<http://www.radiance-online.org/pipermail/radiance-dev/2003-October/000221.html> http://www.radiance-online.org/pipermail/radiance-dev/2003-October/000221.html
P.S. For some reason, the source auxiliary files are not included in
the HEAD distribution. The following files are missing:
ray/src/common/tmesh.cal
ray/src/cv/lamp.tab
ray/src/cv/source.cal
ray/src/cv/tilt.cal
ray/src/gen/clockface.hex
ray/src/gen/glaze1.cal
ray/src/gen/glaze2.cal
ray/src/gen/illum.cal
ray/src/gen/rev.cal
ray/src/gen/skybright.cal
ray/src/gen/surf.cal
ray/src/rt/rayinit.cal
Sent: Tuesday, January 20, 2015 10:02 AM
Subject: [Radiance-general] Installing Radiance on OS Yosemite_make: *** [serial.unf] Error 127
Dear all,
I wanted to install on Mac/Yosemite/ Radiance
rad4R2supp.tar.gz
Xcode is installed and updated for compatibility with OS Yosemite*
following the instruction :https://www.youtube.com/watch?v=ptTmdKSfK68#t=137
I believe I have done something wrong installing it:
#after setting the Raypath , Path and Manpath as in the video
#I have unpacked benchmark
#typed :make (command)// "i have one processor"
and experienced the following error
CHANGES
2010-12-01 MJS reworked Makefile and options so that same code will
work on any version of Radiance going back ~5 years
2011-03-24 MJS removed "-pm 0.0" from optionsbase because rpiece throws
an error in 4R1
Niyas-iMac:bench4 niya$ make
/bin/sh: rpict: command not found
rm -f serial.unf
time rpict @viewpoint @options -x 2048 -y 2048 -t 60 -o serial.unf scene.oct
rpict: No such file or directory
0.00 real 0.00 user 0.00 sys
How do you solve such problem in order to proceed with installing Radiance on Mac?
Best Regards,
Niya
