install Radiance on Mac
I am completely new to Radiance and I am trying to install it on my Mac. I have Yosemite 10.10.5. I have to use Radiance for my Master thesis.
I am already having a hard time in the installation. I am trying to follow the video tutorial on the official website but it refers to an old version (of both website and Mac software): everything is a little bit different and I am doing something wrong. I can’t even start: as I type the command -xzf in order to extract the files, the terminal says: “command not found”.
Does anyone know what I am doing wrong? Is there an updated tutorial where I can see what I have to do step by step?
Thank you!
Marta
If you are trying to unzip the latest release, the command is most likely:
tar -zxf rad5R0all.tar.gz
-zxf is options for the tar command, and the file name being unzipped is at the end.
Here are my personal notes for installing on Mac and Linux (arrow > means command line, double quotes means replace with appropriate file name, brackets are notes):
1) install XCode from App Store
2) install X11
3) compile, by running these commands
> tar -xzf "radiance_release"
> tar -xzf "HEAD"
> cd ray/
> sudo ./makeall install
(use default, or direct to newly made 'bin' folder)
(use default, or direct to 'lib' folder)
> ./makeall library
(direct to 'lib' folder)
4) update your paths
> nano ~/.profile
Put these three lines in the .profile text file, replacing the appropriate paths. Your paths will look different, but they are the paths to the 'bin' 'lib' and 'doc' folders created during the installation. If you're on a Mac, the file will most likely be empty. If it's not empty, you can add these three lines anywhere in the file.
export PATH=/Users/chris/Applications/rad50/ray/bin:$PATH
export RAYPATH=.:/Users/chris/Applications/rad50/ray/lib
export MANPATH=/Users/chris/Applications/rad50/ray/doc/man
5) close and reopen terminal, and test installation
> which mkpmap
> man mkpmap
Download mark stock's benchmark, open a terminal, change to the appropriate directory, and type:
>tar -xf bench4.zip
> cd bench4
(for single core, type:)
>make
(for multi core, type:)
>NCPU=2; make smp
It will take a bit of practice and patience to get familiar with the Unix command line, so give it time and take plenty of breaks (I recommend going to the gym).
Hope this helps,
Chris
On 9/27/15 6:48 AM, Marta Benedetti wrote:
Thank you!
Marta
I am still stuck on the first steps… as I type the command
I get the message:
tar: Error opening archive: Failed to open ‘rad5R0all.tar.gz'
What does it mean?
Il giorno 27/set/2015, alle ore 16:17, Chris Kallie <[email protected]> ha scritto:
2) install X11
> tar -xzf "HEAD"
> cd ray/
> ./makeall library
> nano ~/.profile
> which mkpmap
> man mkpmap
>tar -xf bench4.zip
> cd bench4
>make
>NCPU=2; make smp
Hope this helps,
Chris
Thank you!
Marta
Where do you want the library files [/usr/local/lib/ray]?
What should I type?
Il giorno 27/set/2015, alle ore 17:16, Marta Benedetti <[email protected]> ha scritto:
I get the message:
What does it mean?
Il giorno 27/set/2015, alle ore 16:17, Chris Kallie <[email protected] <mailto:[email protected]>> ha scritto:
2) install X11
> tar -xzf "HEAD"
> cd ray/
> ./makeall library
> nano ~/.profile
> which mkpmap
> man mkpmap
>tar -xf bench4.zip
> cd bench4
>make
>NCPU=2; make smp
Hope this helps,
Chris
Thank you!
Marta
Hi Marta,
You should just download and use the package installer from NREL:
  Release 5.0 · NREL/Radiance · GitHub
It's much easier than compiling from source for those not used to such things. Since you're on a standard OS X distribution, you should have no problem. The recommendations for installing X11 and the developer tools still apply, however.
Subject: Re: [Radiance-general] install Radiance on Mac
Date: September 27, 2015 8:22:25 AM PDT
What should I type?
I get the message:
What does it mean?
2) install X11
> tar -xzf "HEAD"
> cd ray/
> ./makeall library
> nano ~/.profile
> which mkpmap
> man mkpmap
>tar -xf bench4.zip
> cd bench4
>make
>NCPU=2; make smp
Hope this helps,
Chris
Thank you!
Marta
P.S. Scroll down the page to find the "Darwin" disk image, which is for Mac OS X (code named "Darwin" by developers, not by us).
Date: September 27, 2015 8:31:39 AM PDT
Hi Marta,
Bello greg,
That's what I did, I downloaded the pre-compiled binary for Mac OSX. So what should I do next?
I can't create libraries and so on because I have absolutely no idea how to do... I want to cry!
Sorry but I feel completely ignorant in this subject.
Marta
Il giorno 27 set 2015, alle ore 17:32, Greg Ward <[email protected]> ha scritto:
Hi Marta,
What should I type?
I get the message:
What does it mean?
2) install X11
> tar -xzf "HEAD"
> cd ray/
> ./makeall library
> nano ~/.profile
> which mkpmap
> man mkpmap
>tar -xf bench4.zip
> cd bench4
>make
>NCPU=2; make smp
Hope this helps,
Chris
Thank you!
Marta
Marta,
Not too many years ago, I was in the same place as you, and I fortunately had help from Rob Shakespeare (one of the authors of the book "Rendering with Radiance"). So, the least I can do is pass on the knowledge to the next generation of users. If you are still stuck after some trial and error, I would be happy to help out via personal communication.
If one looks back on the archives of this list, there is a constant exodus of young users who disappear after they get their masters/PhD's, so I am playing my part to take some of the burden off the senior developers by offering a little help here and there to the new users...
PS. for those who have read this far: How is the new knowledge base platform working? I was happy to hear there were some recent efforts, but I haven't seen or heard about it for a few weeks.
Chris
On 9/27/15 11:37 AM, Marta Benedetti wrote:
Bello greg,
Marta
Il giorno 27 set 2015, alle ore 17:32, Greg Ward > <[email protected] <mailto:[email protected]>> ha scritto:
Hi Marta,
*From: *Marta Benedetti <[email protected] <mailto:[email protected]>>
*Subject: *Re: [Radiance-general] install Radiance on Mac
*Date: *September 27, 2015 8:22:25 AM PDT
What should I type?
Il giorno 27/set/2015, alle ore 17:16, Marta Benedetti >>>> <[email protected] <mailto:[email protected]>> ha scritto:
I am still stuck on the first steps� as I type the command
I get the message:
tar: Error opening archive: Failed to open �rad5R0all.tar.gz'
What does it mean?
Il giorno 27/set/2015, alle ore 16:17, Chris Kallie >>>>> <[email protected] <mailto:[email protected]>> ha scritto:
2) install X11
> tar -xzf "HEAD"
> cd ray/
> ./makeall library
> nano ~/.profile
> which mkpmap
> man mkpmap
>tar -xf bench4.zip
> cd bench4
>make
>NCPU=2; make smp
Hope this helps,
Chris
I am already having a hard time in the installation. I am trying to follow the video tutorial on the official website but it refers to an old version (of both website and Mac software): everything is a little bit different and I am doing something wrong. I can�t even start: as I type the command -xzf in order to extract the files, the terminal says: �command not found�.
Thank you!
Marta
Hi Chris,
I had replied to one of those emails from afternoon. I think the Penn State
webmail server isn't smart enough to figure out the difference between
personal emails and mailing lists.Anyway, my reply is below..
Actually, if you got as far as "Where do you want the library files.", you
can just follow along with Andy's video from around the 4:59 mark..
Instead of typing any directory or path names you can just keep pressing
enter( or return) to select the default options.
Sent: Sunday, September 27, 2015 6:15 PM
Marta,
Chris
Bello greg,
should I do next?
Marta
Il giorno 27 set 2015, alle ore 17:32, Greg Ward <[email protected] <mailto:[email protected]> > ha scritto:
Hi Marta,
[email protected]>
What should I type?
Il giorno 27/set/2015, alle ore 17:16, Marta Benedetti <[email protected] <mailto:[email protected]> > ha scritto:
I am still stuck on the first steps. as I type the command
I get the message:
tar: Error opening archive: Failed to open 'rad5R0all.tar.gz'
What does it mean?
Il giorno 27/set/2015, alle ore 16:17, Chris Kallie <[email protected] <mailto:[email protected]> > ha scritto:
the end.
2) install X11
tar -xzf "HEAD"
cd ray/
./makeall library
nano ~/.profile
which mkpmap
man mkpmap
tar -xf bench4.zip
cd bench4
make
NCPU=2; make smp
to the gym).
Hope this helps,
Chris
I am doing something wrong. I can't even start: as I type the command -xzf
in order to extract the files, the terminal says: "command not found".
Thank you!
Marta
Hi Marta,
Sorry this is all so confusing! Sounds like you grabbed the pre-built binaries from the NREL site. Let’s see if we can get you the rest of the way.
1. Make sure you have the right installer. If you’re on MacOS, you want this one:
https://github.com/NREL/Radiance/releases/download/5.0/radiance-5.0.0-Darwin.dmg
2. Double-click the installer ("radiance-5.0.0-Darwin.dmg”), and then double-click the file inside ("radiance-5.0.0-Darwin.pkg”). Click “continue”, three times. Finally, click “install” to run the installer accepting the default location(s) for everything.
You now have Radiance installed on your mac. What this really means is that you have a while bunch of files installed to the following locations:
/usr/local/radiance/bin (the Radiance executables — of which there are many, and ironically none of which are called “Radiance”)
/usr/local/radiance/lib (the Radiance “library folder” which contains loads of other important files used by Radiance)
/usr/local/radiance/man (the Radiance “man pages”, or manual pages — the main documentation to the Radiance programs
At this point, nothing actually works yet. =/ But, you’re close...
3. Next you need to add "/usr/local/radiance/bin” to your system path, and you need to create a new system variable called “RAYPATH” and set it to "/usr/local/radiance/lib”. You can/should also add "/usr/local/radiance/man” to your MANPATH system variable. You can see Andy McNeil demonstrate using “pico” to do this, starting at 7:38 in the video here:
NOTE: Be sure to use the paths I mention in this email and not the ones in Andy’s video.
After you do these three steps, you will have Radiance installed and functional. Then the fun really begins. =) Be sure to check out the tutorials here:
http://www.radiance-online.org/learning/tutorials
…and post any questions either here on this list, or over on Unmet Hours (https://unmethours.com/questions/\). There are plenty of folks who are still here answering questions and offering advice, long after getting Ph.D.s. Matter of fact, some of us never even got Masters degrees. Still here.
-Rob
Reply: Radiance general discussion <[email protected]>>
Date: September 27, 2015 at 9:37:50 AM
To: Radiance general discussion <[email protected]>>
Bello greg,
Marta
Hi Marta,
What should I type?
I get the message:
What does it mean?
2) install X11
tar -xzf "HEAD"
cd ray/
./makeall library
nano ~/.profile
which mkpmap
man mkpmap
tar -xf bench4.zip
cd bench4
make
NCPU=2; make smp
Hope this helps,
Chris
Thank you!
Marta
Hi, I have been struggling to install Radiance on my Mac Os as well.
So far I have only been using it on a Windows PC. I have seen many references to Andy McNeil video in the posts that are a few years old but the video is not currently available and I couldn’t figure how to define the variable and set the paths.
I have downloaded the latest version from NREL. When I used the .pkg* file I couldn’t find the Radiance folder including the bin, lib and man on my Macintosh HD under user (or anywhere else?!), while the installation was successfully completed.
But with the OSX.zip* file all the folders are already there after extraction, but do I need any kinds of installation?
And I am not sure how to start executing commands on Mac, how do I start Radiance on Mac Terminal?
I would appreciate your help.
Have you downloaded the binaries from LBNL? The NREL binaries have not been updated in some time; that whole project (code support, installer builds, testing) has been moved entirely to a different GitHub repository at LBNL’s site, and it’s my understanding that the MacOS installer(s) have been improved quite a bit, handling the path stuff automatically for you.
Check here and you will see there is a current installer just two days old.
