Illuminance Map
Hi All
In EnergyPlus , by the use of “ Daylighting:Controls “, daylighting illuminance levels are calculated and then used to determine how much the electric lighting can be reduced.
Estimating daylight will not be affected by the size of illuminance map. However, by the use of radiance I noticed that Illuminance map size will have an effect on the results of the energy consumption of a building (Energy Per Conditioned Building Area). I did not understand why the illuminance map will affect such results ….
Thanks all
Khalid
Hi Khalid,
Nope, size of the illuminance map should not affect the reported energy savings. The savings in the latest OpenStudio versions are based on the illuminance at the daylighting control point, and of course the setpoint.
What version of OpenStudio are you using? I am happy to look at your model and your test process so we can see what's going on there. I'm on vacation this week but have access to email, just sporadically. Let me know how I can help!
Rob
Rob Guglielmetti
NREL Commercial Buildings Research Group
Golden, CO 80401
robert.guglielmetti@nrel.gov
From: Khalid [khalid.ud@gmail.com<mailto:khalid.ud@gmail.com>]
Sent: Tuesday, March 26, 2013 03:13 PM Mountain Standard Time
To: 'Discussion of Radiance with OpenStudio'
Subject: [Radiance-openstudio] Illuminance Map
Hi All
Thanks all
Khalid
Thanks Rob,
I think I’m not opening the right results files … the first result will come from this location: … /AppData/Local/Temp/qt_temp.gg4416/radout
… I did run several models by using Openstudio 10.3 … but for some reasons, the folder: “0-Ruby” disappear from the ‘Run’ folder ….
I do not knew why when opening the results from the result viewer in openstudio .. I did not get the results directly from the same folder of the model.
One more question Rob, is it possible now to run Radiance for a selected period of the year, or not yet. …..Thanks
Khalid
From: Guglielmetti, Robert [mailto:Robert.Guglielmetti@nrel.gov]
Sent: 27 March 2013 18:07
Subject: Re: [Radiance-openstudio] Illuminance Map
Hi Khalid,
Rob
Rob Guglielmetti
Golden, CO 80401
Hi All
Thanks all
Khalid
