I'm after both. (Renderings and falsecolor images mostly, but rtrace
calcs as well). Not sure I understand why it's such a bad idea to place
an illum plane on the outside of a window. (I am not using my glass as
the illum planes). Guess I'm going to have to try out a few test case
scenarios and see what seems to work better before running the real
thing.
Mark
Mark de la Fuente wrote:
Lars,
I wish I could attach images, as perhaps there is another way to do
this. But the reason for the exterior illums is that the interior
architecture follows the windows, forcing me to use triangular illums
at
some point if I am to seal each opening. (window panes are not
rectangular either) Or each opening can be sealed from the outside.
Hi Mark,
Yeah, triangular polygons are not a good fit with mkillum, because of
the way source sampling works. The triangular polygons are usually the
source of the "aiming failure" errors seen when running mkillum. The
best explanation is of course in the Rendering with Radiance text. Do
you have a copy? If so, this problem is addressed on pg 577.
Your building seems a challenge for mkillum. Are you trying to create
pretty pictures, or get some illuminance data at points? If the
former,
it may still be worth the effort to try and seal your opening -- from
the inside -- with a combination of polygons less likely to generate
failures. If the latter, it's probably best to simply crank up the
ambient calculation parameters, and wait it out. (This method could
also be used for pretty picture generation, but now you're talking
about
*really* waiting...
Rob Guglielmetti
e. rpg at rumblestrip.org
w. www.rumblestrip.org
Hi Mark,
in short, the illums help you to reduce the errors which are caused when the ambient calculation sends out its random samples. If the lightsource (or illum) is outside, than the geometry between the source (or illum) will still cause errors. You can answer this by either setting the ambient paramters higher (so that every detail of your geometry is hit, which is very slow) or place the illum on the inside.
You might try to break down your illum panes into smaller surfaces. Don't use too much, as this will also slow down calculation, but maybe if you divide each face into some smaller faces, you can use rectangles?
As Rob said, if you can take a look at the chapter in "Rendering with Radiance", that might explain a lot.
Good luck, Lars.
Am Freitag, 30.07.04 um 23:25 Uhr schrieb Mark de la Fuente:
I'm after both. (Renderings and falsecolor images mostly, but rtrace calcs as well). Not sure I understand why it's such a bad idea to place an illum plane on the outside of a window. (I am not using my glass as the illum planes). Guess I'm going to have to try out a few test case scenarios and see what seems to work better before running the real thing.
Mark
Lars O. Grobe
Lars O. Grobe, [email protected], ++90-212-2458330
Kardesler Apartment, Turnacibasi Sokak 28
Galatasaray - Beyoglu, 34433 Istanbul
Neither do I...
If you have windows with lots of subdividing geometry, then in
most cases the optimal solution is to turn each subpane into an
illum. In cases where this would create too many illums, or
illums with very non-rectangular shapes, it may be better to
place a big illum on the inside *or* the outside of the windows.
None of the two positions is inherently better or worse than the
other.
Advantages inside:
- Internal rays will hit the illum directly, which improves speed
and smoothness of the rendering.
- You can make one or several illums per opening, depending on
how close it is to any other geometry (the farther away the
other geometry is, the larger the illum can be)
Disadvantages inside:
- Some of the rays cast by mkillum will hit your window geometry.
Depending on the number of sampling positions (s=) and the type
of geometry, this may negatively affect the accuracy (more or
less rays may hit window geometry than statistically justified).
Since the sampling positions are determined at random, this
effect is hard to predict, let alone to correct. The need to go
through the window geometry will also slow down mkillum to some
degree.
Advantages outside:
- Since there is no obstruction by the window geometry, the
values generated by mkillum will be very accurate, and the
speed of the mkillum runs will only be determined by the
complexity of your exterior scene.
external obstruction. If one part of an opening is shaded eg.
by a tree, you can make that part an extra illum, which avoids
averaging between areas of different illuminance.
Disadvantages outside:
- Direct sampling from the inside will have to get past the
window geometry to hit the illums. This can affect both
rendering speed and accuracy. You can improve the accuracy by
suitable values for -ds and -dj (you should set those anyway
when using illums). You can also subdivide your illums in a way
that makes it more likely that their centers will be close to a
clear part of your window geometry.
Considering all that, I wouldn't hesitate at all to place your
illum surfaces outside in your situation.
-schorsch
Hi!
But what about the indirect calculation? As far as I understood, it is one of the main reasons to use illum surfaces at the windows to reduce the errors caused by the ambient calculation, which can cause visible artifacts. And this problem could still arise if the illum is placed outside. Am I wrong here?
CU Lars.
Lars O. Grobe
Lars O. Grobe wrote:
Hi!
The purpose of mkillum is to reduce the calculation required
outside your space. Reducing artifacts is a secondary effect.
It happens because the illum surface averages the large variety
of luminances found outside. Window geometry between the space
and the illum may have some adverse effect, but it should be
minor in comparison to the improvements mkillum gives you in
either case.
As always, need to weight the pros and cons in the context of
your actual scene.
-schorsch
